Old 01-19-2020, 12:05 PM   #1
ernesto rex
ernesto rex is on a distinguished road
ernesto rex's Avatar
2000 L-Series 3.0L Sedan
2003 VUE 3.0L
Default Oil Pan Sealant Replacement
I have searched in the forums and failed so now I ask.
Has anyone removed the oil pan on the 3.0 V6 and resealed? I have an oil leak that seems to be coming from that area. The ALLDATA DIY instructions makes it look simple.
ALLDATA DIY: Trust but verify.
2000 LS2
2003 VUE 3.0 FWD
2002 MINI Cooper R50
1978 GMC PU 7.4L
Add to ernesto rex's Reputation
Rate the quality of this post and help ernesto rex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ernesto rex is offline   Reply With Quote
Old 01-19-2020, 12:35 PM   #2
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: Oil Pan Sealant Replacement
Resealing the oil pan is simple enough. Removing the exhaust to gain access is the difficult part on the V-6. You must disconnect the oxygen sensors and drop the front section with the small cat converters. The difficulty depends on the corrosion level on your car.
Add to 02 LW300's Reputation
Old 01-25-2020, 11:26 AM   #3
ernesto rex
2003 VUE 3.0L
Took a look under the car on Wednesday and saw exactly what you were talking about regarding removing the exhaust before dropping the oil pan.
I did notice that one of my cam shaft cover bolts was loose on the 2-4-6 bank. I was fairly certain I had all those tight when I replaced that gasket this summer. Tightened it up and cleaned all the oil gunk underneath.
Under observation for now.
2000 LS2
2003 VUE 3.0 FWD
1978 GMC PU 7.4L
Sealant Tyson L-Series General 11 08-03-2019 05:32 PM
Sealant ?? ... Or NOT ? Rickw123 Vue Tech 3 10-18-2015 05:25 PM
Anyone do their own oil cooler sealant? s3nfo L-Series Tech 1 02-13-2006 06:24 PM
A/C fix using sealant kit angusW S-Series General 2 09-15-2005 04:47 PM
Sealant-Oil Pan? 91SL2 Miscellaneous Tech 2 10-15-2002 11:36 AM
