![]() Join Date: Apr 2008
I have a 2003 ION Quad Coupe and the headlights do not work (no low beams, no high beams). Where is the headlamp relay located and what does it look like? The service manual says it is at the lower left of the instrument panel, near the diagnostic link connector. I don't see anything that looks like a relay to me. I also have an '04 ION and have swapped bulbs aroound and the bulbs in the 03 are good. I am getting voltages at the connectors to the bulbs. Is there anything else I should be looking at?
![]() Join Date: Jun 2007
take the entire headlight housing out and look behind it attatchted to the side of the engine compartment almost opposite the tire. its white and small and most small gm cars have the same one, i know cause one of mine cracked and i looked everywhere for a new one only to find that all pontiac sunfires and cavaliers had the same housing.
Welcome to the Board.
Your info on the relay location seems good. Check th eowners manual to see if it gives a different location. See if you are getting ground on the dark blue wires. From there you may have BCM problems or grounding problems via the BCM.
A lousy day in paradise is still a day in paradise. |
Thanks for the replies, but I didn't see anything behind either headlight housing that looks like a relay. I traced the wire bundle on the passenger side. The only place it went was to the driver side. The wiring from the driver side headlights disappeared into a larger bundle that seems to go into the passenger compartment. Any other ideas?
2004 Saturn ION quad coupe | bart888 | Ion General | 2 | 12-30-2010 09:21 PM |
FS: 2004 Ion-3 Quad Coupe -- SF Bay area | rajpaul | Classifieds | 0 | 04-19-2006 06:02 PM |
2004 Saturn ION 3 Quad Coupe - MT, SR, ABS, 6 CD - $12,499 | SaturnGuy3 | Classifieds | 0 | 11-05-2004 01:44 PM |
2004 Saturn ION 3 Quad Coupe only $11,999 | SaturnGuy3 | Classifieds | 2 | 10-15-2004 08:11 PM |
Wanted: Anything for 2004 ION Quad Coupe | LNCRES2 | Classifieds | 3 | 12-22-2003 12:34 AM |
