Old 06-04-2007, 08:33 PM   #1
1993_SL2driver
1993_SL2driver is on a distinguished road
Default A/C Refrigerant
Would the A/C system in a 1993 SL2 need to be retrofitted to R134 or is it already. My car has good refrigerant pressure, it just doesn't get cold enough to keep you comfortable. Any help would be appreciated.
Thanx
Add to 1993_SL2driver's Reputation
Rate the quality of this post and help 1993_SL2driver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993_SL2driver is offline   Reply With Quote
Old 06-04-2007, 08:49 PM   #2
geartooth94
geartooth94's Avatar
Default Re: A/C Refrigerant
check the label that is on the radiator support from the factory. it will tell you what it came with originally.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 06-07-2007, 05:04 PM   #3
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: A/C Refrigerant
Thanx
I think you have R12? in late 93 or 94 they went to R14a?
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-07-2007, 06:36 PM   #4
If the underhood area is missing the label indicating what refrigerant system is used you can remove the valve caps to identify the system; R12 uses externally threaded service fittings while R134a uses quick couplers and are not externally threaded. In other words, R12 requires a hose fitting that screws on over the service fittings while R134a requires a type of hose fitting that quickly connects with a snap-on like coupler similar to air tools that uses quick connect fittings. Both fittings uses the same schrader valve that screws on/off internally just like the tire valves.
R12 - screw on fitting
R134a - quick coupler fitting
Old 06-07-2007, 06:58 PM   #5
97coupe
97coupe is on a distinguished road
Good quick tip!
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Pink Puddle - Refrigerant? stonecoldsw L-Series Tech 2 09-13-2008 08:44 PM
alternative refrigerant paqrat S-Series Mods 18 09-12-2006 04:39 PM
A/C Refrigerant Leak mirandm S-Series Tech 4 09-03-2006 09:56 AM
add refrigerant tasme80 L-Series General 3 05-20-2005 01:36 PM
ac refrigerant leak lewis2 L-Series General 13 07-15-2004 06:29 AM
