Old 01-26-2014, 04:22 PM   #1
kimblarry
kimblarry is on a distinguished road
Default Mass Air flow sensor connector/ pigtail needed
I need this part, I have been searching gm sites and ebay for this with no luck. Please help me find this piece. The check engine light is always on, bought a new mass air flow sensor part, and put it on and the check engine light is still on. The computer to check the codes and the mechanic said it was a mass air flow sensor problem. He was the one who suggested it was the pigtail/connector that was probably not working and recommended it to be replaced.
kimblarry is offline   Reply With Quote
Old 01-27-2014, 08:24 PM   #2
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
Default Re: Mass Air flow sensor connector/ pigtail needed
Have you tried a junk yard?
phatfire6 is offline   Reply With Quote
Old 01-27-2014, 11:39 PM   #3
satlite440
2001 SL2
what kinda mechanic is this?????wtf??? very simple ckt to ck power& gound&5vt reference. they are eather there or not.eather you can see pin damage to the connecter.or not..i think you need a new mechanic bro..i would bite the bullet and pay the 1 hr diag to have the maf ctks tested and pin dragged by a gm dealer before i strted hacking up my harrness.. also if the dealer finds bad pins they can replace them indaviualy....
Old 01-28-2014, 03:25 PM   #4
redeka
redeka is on a distinguished road
I have included a diagram of the connector I think you are referring to. You may be able to have a peek yourself to see if it really is the source of your problems.
If you still find yourself needing a part, I have always found things like this in my area through car-part.com
redeka is offline   Reply With Quote
Old 05-08-2018, 04:06 PM   #5
EN1
EN1 is on a distinguished road
where did you get that diagram? i found a diagram and the part numbers are different, i just want to compare. TIA
EN1 is offline   Reply With Quote
Old 05-08-2018, 04:08 PM   #6
EN1
did you ever find this part, i have searched the past 6 hours and can not find it. i called the gm dealer and they can not find it, not even the plug.
Mass Air Flow Sensor Kgscott86 L-Series Tech 4 07-19-2011 08:10 PM
Mass Air Flow Sensor...Help!! tosha Ion Tech 2 05-29-2009 10:00 AM
Mass Air Flow sensor 2000-LS2 L-Series Tech 12 11-09-2007 06:40 PM
Mass Air Flow Sensor beensmoked L-Series Tech 0 12-16-2006 12:01 PM
No Mass Air Flow sensor?? Greg1 Miscellaneous Tech 2 09-24-2003 09:25 PM
