Old 08-14-2006, 12:12 AM   #1
bmd473
bmd473 is on a distinguished road
Default 2003 Vue Startup Problem
A couple of months ago, my Vue (2003, V6 FWD) would not start when my wife turned the key, the engine would crank, but nothing else. I went out to the car a couple of hours later (when I got home from work) and it started fine for me.
Today, it is doing it again. When I turn the key, the car cranks but nothing. Only this time after I waited several hours, it still won't turn on. If I turn the key to the run position, the lights on the dash board turn on, the radio turns on and the the windows work, so I don't think it is the battery. Also, when I turn it to run, the security light turns off after a couple seconds so I don't think it is a security issue. Does anyone have any ideas or has this happend to them? Thanks.
bmd473 is offline   Reply With Quote
Old 08-14-2006, 12:32 AM   #2
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default Re: 2003 Vue Startup Problem
Do you hear any clicking from the starter solenoid?
2006 Black VUE Red Line - Now running iOS 14.7 beta
Old 08-14-2006, 08:27 AM   #3
bmd473
Yes. That is all that happens. It is just a clicking noise when I turn the key.
Old 08-14-2006, 10:42 AM   #4
1saxman
If it's cranking but not starting, you may have a more serious issue. If it's clicking but not cranking, you may just have corrosion on the battery terminals, it may need a new battery or you may have discharged the battery trying to start it.
Are you sure the car is not out of gas? If it's just clicking, the battery will have to be cleaned, charged or replaced before you can do anything else. If it's cranking but not starting and there's gas in it, you probably will have to have it towed in.
Old 08-14-2006, 10:44 AM   #5
bmd473
My mistake earlier. The only thing that it is doing is clicking when I turn the key. Would it be the battery even if all the lights come on, the radio works, and the windows roll down when I turn the key to the run position?
Old 08-14-2006, 12:56 PM   #6
SLAPSHOT
SLAPSHOT is on a distinguished road
SLAPSHOT's Avatar
It's most likely your battery, no big deal, buy a new one. I'd have the alternator checked as well just for good measure, but my money's on a dead battery. Yes, your electric system can still work with what little is left in the battery, you just don't have enough juice to turn the motor.
//SLAPSHOT//
05 VUE 2.2L 5 Speed
SLAPSHOT is offline   Reply With Quote
Old 08-14-2006, 12:59 PM   #7
GearGuy
GearGuy is on a distinguished road
GearGuy's Avatar
1 click with each turn of the key or do you hear a few clicks? Do the interior lights dim?
It takes a good bit more amperage to get the engine to turn over. So the radio could still play fine even if the battery is dying.
There are auto stores that can test a battery for you. Advance Auto and Pep Boys come to mind. If you drive it in the could test the charging system as well. Just to make sure that nothing is boderline bad.
Check the battery cables and cables running to the starter for corrosion. See if anything is loose. A poor connection with the ground cable could also lead to trouble.
2006 Vue 3.5L FWD
GearGuy is offline   Reply With Quote
Old 08-14-2006, 01:01 PM   #8
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
Saxman pretty much summed it up in his post.....
To answer your question, yes, you can have the lights come on, radio, and windows work, yet the car will not start....
See if the cables to the battery posts are real secure and not corroded (especially the positive post - clean if dirty). If they are tight, and not corroded, recharge your battery or get a jump from someone. The clicking is your solenoid which switches on your starter (starter may have loose a cable). Its been a while since I have had this problem (the farm days...hmmm...LOL), but I would see how bright the lights are...if real bright (not dim), I would check the cable to the starter (its rare, but someone they are loose).
mellissam is offline   Reply With Quote
Old 08-14-2006, 03:41 PM   #9
body-snatch-her
body-snatch-her is on a distinguished road
body-snatch-her's Avatar
You can try jump starting with booster cables (be very careful to do it right) and if it starts then you know it's related to the battery and/or charging system and after it's started you can proceed to the parts place for alternator testing/battery replacement as described above. In any case make sure the cable clamps are clean by washing with a baking soda solution or even better replace them with new ones since they can get oxide glazed over time. If the car won't jump start then it's likely a larger issue which you likely will need a professional to diagnose and repair (assuming you had fuel in the tank when the problem started).
"Together we WILL destroy the planet! (Evil Plot 2-B)"
body-snatch-her is offline   Reply With Quote
Old 08-14-2006, 07:57 PM   #10
bmd473
Default Re: 2003 Vue Startup Problem - Update
Took the battery to O'Reillys tonight where it tested bad. Bought a new battery and the Vue seems to work fine. Thanks for all the replies and I will definitely remember this site in the future.
Old 08-15-2006, 02:30 AM   #11
GearGuy
GearGuy's Avatar
Well, glad to hear it was a minor problem.
I think the typical battery life is about 3 years.... Pretty low...
Stop back anytime.
It always helps to have people share their personal experiences...
2006 Vue 3.5L FWD
Old 08-15-2006, 08:48 AM   #12
mr weather
mr weather is on a distinguished road
Yeah, 3 years sounds about right. Just after the warranty expires...
Although, my last car (1995 Cavalier) got over 7 years out of the OE battery.
Heat is the enemy. Glad the battery in my ION is in the trunk.
mr weather is offline   Reply With Quote
Old 08-15-2006, 09:05 AM   #13
SLAPSHOT
SLAPSHOT's Avatar
I really liked that about the ION's I had.....it also makes installing amps alot easier.
//SLAPSHOT//
05 VUE 2.2L 5 Speed
2003 VUE a/c problem texast Vue General 5 06-30-2008 10:28 AM
2003 Vue 2.2 Carbon Problem Rick M Vue Tech 6 06-24-2008 01:29 PM
2003 ion2 over cranking\sticking on startup phillthy Ion Tech 10 12-18-2007 09:49 PM
2003 Vue cluster problem jr3755 Vue General 4 04-01-2007 06:11 PM
2003 Vue AC problem jim43bob Vue Tech 3 07-23-2006 06:22 AM
