Old 03-05-2009, 03:05 AM   #1
lockbox
lockbox is on a distinguished road
Wrench SC2 Starter Issues
First post under this User name, have no idea what my old one was, 5 years ago. It is about a 2002 SC2 3 door, 1.9, DOHC, Auto, with a broken sunroof, (but aren't they all), and a dead/dying starter.
What I have done so far. Noticed that starter for 3 days was turning car over slowly. On day four, I was panicked about a late appointment, and ground it until I knew I was being stupid. Then I found a ride with a friend.
Since then, I tested battery, (marginal), replaced it. Checked all fuses, in engine compartment and on passenger side footwell. All appear good. (Tomorrow, I VOM test them).
Checked Fusible link between Alternator and Starter, (two handed, under car, on low jack stands, in rain no less), and it showed continuity. I checked it 3 times, just to make sure. Grumble.
Finally I pulled the starter out, and took it to (chain name deleted) for their "No load" bench test. I think I frustrated him, by testing it 7 times. Worked like a charm, spun fast and clean, for each of the 1 minute tests.
Read more forum postings: Focusing on "don't forget the stupid stuff".
Pulled positive battery terminal off, cleaned with contact cleaner, brush, and copper penny. Replaced it *tight*. (Negative is still off, as I have to R/R the starter still).
Checked each fuse again.
Took starter, tested it in kitchen, (bachelor, I can get away with this), on the much less charged replaced battery, and it still functioned normally, but slower. To be expected. It even cranked with my thumb grinding *hard* against the spindle. It got weak as the battery voltage dropped below 10.5 volts.
*Then* I read another 14 pages of saturn fan forums, focusing on starter/battery issues.
So, tomorrow, I climb back under the car, replace the original starter, and try again.
Did I miss a hidden starter Relay, or inline fuse someplace?
I am leaning towards rebuilding it myself or perusing the junk yards near home. 130 bucks for a chain store starter is kind of a pain, and my travels often include the middle of the desert, far from roads and parts stores.
My other cars:
My 1994 SL2 was bought from my Ex wife, for 300 bucks. It had a leaky radiator, and a 10 degree mismatch between Engine Temp Sensor, and Trans temp sensor that stumped Saturn for a week. It had 105,000 miles on it. 7 years later, it has 167,000 miles on the odometer. But that gauge broke less than a year, after I bought the car from her. Mileage Now?... 280K? 320K? Only issues, Reverse pop, and Headliner from hell, and smokes when I stomp on the gas.
It was replaced recently with a 2002 SC2, which I am just learning the idiosyncrasies of. Bought used at 56,000 miles, now has 62,000 miles
Grumbling about not being able to "paper clip" to get computer codes.
The sunroof fuse has been removed to prevent guests from opening when, it will cost 1200 bucks to replace the belt, and close again.
Oh, I can fit a 35 inch (CRT) television in my back seat via the 2 door.
Add to lockbox's Reputation
Rate the quality of this post and help lockbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lockbox is offline   Reply With Quote
Old 03-05-2009, 10:41 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: SC2 Starter Issues
Start with the first car... Have you looked into the CPS. Is the car cranking but not starting?
Second car... try doing a reverse slam cure in the How-To library. As far as smoking is concerned, the car is probably running rich. What I would do is get the right ECT, make sure the connector is good, do a TB clean and possibly replace the IAC vavle. Mainly the smoke is caused by burning oil due to the magnificent piston rings in these cars. Look into doing an MMO soak which is also in the How-To.
Getting codes from the PCM. Go to advanced auto, pepboys or something like that... they will run a diagnostics test on the car for free.
Saturnless...
Old 03-05-2009, 04:26 PM   #3
lockbox
First Car. Not cranking.
Second Car, on hold, until first car is running.
Old 03-05-2009, 04:35 PM   #4
OnDaGround
OnDaGround's Avatar
1993 SC2
Hmmm. Well starter is "good", cps is not bad or it would crank. How are the plugs, wires and coil. If you keep getting a low voltage I would look into the battery cables to the starter and to the alternator. I know you said you cleaned them. But pull or cut the sleeve down a bit and check for corrosion. Check them at the starter too. Oh and up top where I recommended to replace the IAC valve, that was a type-o. I meant to say PCV valve but fat fingered instead.
Saturnless...
Old 03-05-2009, 04:54 PM   #5
saturnhouse
saturnhouse will become famous soon enough
Not cranking, but does it 'click?' Can you hear the solenoid?
If no click - could be a bad switch, wiring, or the solenoid itself. Check for 12V on the solenoid when the key is turned.
Turn on the headlights and see if they dim when you try to start.
If so, then the key/switch is probably OK. If not, it could be the switch, or wiring (fuse?).
If it clicks but doesn't crank, check for 12V on the fat wire to the starter. If you don't see 12V with the key turned, it could be switch, wiring, fuse(?).
Add to saturnhouse's Reputation
Rate the quality of this post and help saturnhouse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnhouse is offline   Reply With Quote
Old 03-05-2009, 06:04 PM   #6
Probably not, if it's not cranking. No way to know yet.
Totally unrelated. The CPS _senses_ crank movement (duh, thus the name). The PCM uses it to initiate spark. If the engine's not cranking, there's no way to know the condition/function of the CPS. CPS has no connection with the starter circuit.
No-crank gen-3, one suspect is RKE/Security. It may have been tripped with battery connects/disconnects. Your owner's manual has a procedure for "resetting" the system, something about leaving the key in the RUN position for 30 minutes while facing Spring Hill and chanting "A different kind of company, a different kind of car". On a Tuesday.
Have you tried starting it in neutral? Or while nudging the shifter from neutral toward Drive and Reverse?
Add to madpogue's Reputation
Old 03-05-2009, 07:16 PM   #7
lockbox
Start Clicks, but does not turn over. Rigged up my own bench test, with 12 Volt source and motor turns, but not enough torque to start a 90CC motorcycle, much less my Saturn, once I put *real* resistance on it. (rubber shoe test).
Found a electrical shop that does rebuilds onsite, with 2 year warranty. About 6 miles from here, for under 50 bucks, including tax.
Will update from there.
All starter bench testers should have a resistance gear, built into them.
Help Please,Remote starter Issues curbstop S-Series Tech 3 12-21-2009 10:39 PM
SC2 Starter Issues lockbox S-Series Tech 3 03-05-2009 11:30 PM
Remote locks/starter issues Seversonic S-Series Tech 4 07-01-2007 11:43 PM
Starter Issues yukisho Ion Tech 6 03-30-2007 12:34 AM
remote starter for hybrid? issues etc.. jlalill Vue Green Line 8 11-14-2006 03:52 PM
