Old 02-06-2014, 01:08 AM   #1
bigfoot92
bigfoot92 is on a distinguished road
Dizzy Buying a '98 SL2, but it loses coolant...
Hey Saturnfans,
I was able to fix most of my problems with my first car by looking through the forum, but this time I really need advice. I'm about to buy a 1998 SL2 tomorrow, and it's only problem is that it needs coolant every two weeks. The car has 160,000 miles on it, but has been well maintained its entire life, does this sound like head gasket to you? What should I do to find out?
Add to bigfoot92's Reputation
Rate the quality of this post and help bigfoot92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigfoot92 is offline   Reply With Quote
Old 02-06-2014, 03:13 AM   #2
Default Re: Buying a '98 SL2, but it loses coolant...
At 160k miles, the usual places for a leak to occur would be the radiator xmission fittings, hoses, and water pump. Head gasket failure would result in coolant turning to chocolate.
Old 02-06-2014, 05:55 AM   #3
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Look for a chocolate milkshake foam in the coolant reservoir tank.
If it's there, head gasket...
Check the cap on the coolant reservoir tank, if it's not sealing, you will lose coolant.
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 02-06-2014, 04:10 PM   #4
The black plastic radiator end tank on the driver side tends to split, too.
Great pics in this thread
http://www.saturnfans.com/forums/sho....php?p=2039356
Old 02-06-2014, 08:31 PM   #5
caliber bob
caliber bob is on a distinguished road
caliber bob's Avatar
1997 SW2
Are you finding coolant on the ground or are you just having to add?
I'd also check the t stat housing. I'm assuming it's on at least its second t stat so I'd check that in case they didn't seal it up good enough and the pressure from the car running is forcing it out there. Also gently wiggle on the radiator hoses. I've personally had a hose clamp cut into the hose and cause a leak. Just my dos centavos
Add to caliber bob's Reputation
Rate the quality of this post and help caliber bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caliber bob is offline   Reply With Quote
Old 02-08-2014, 04:45 PM   #6
bigfoot92
I just bought the car and drove it home. Besides me being terrible at driving manual, I found the problem: the water pump. Turns out the weep hole in the water pump went, so all I have to do is change it out. Thanks for the input! And also, is there any reason why the car does not like to start out in first gear? It's probably just me, but I was wondering...
Old 02-08-2014, 04:51 PM   #7
@160k miles, clutch and/or clutch master/slave unit are worn.
Old 02-08-2014, 10:03 PM   #8
Highmile
Highmile's Avatar
Maybe have a buddy try it that is much better with the manual trans...
Highmile
'95 SL1 535k and counting
Add to Highmile's Reputation
Old 02-09-2014, 12:08 PM   #9
westwind999
1999 SW1
My SL2 had a leak in the headgasket that appeared near the exhaust manifold. It was only a slight drip of coolant down the side of the block. I added the blue Subaru additive that they use for their head gasket problems and it seems to have worked for a while now.
For the 1st gear issue, is it hard to get into first gear when stopped at a stop sign or is it hard to get rolling from a stop?
Car loses power while accelerating? HELP JaceyHeimer S-Series Tech 18 01-02-2012 09:36 PM
'94 SL2 gets axle, loses speedometer WarszawaScream S-Series General 2 04-02-2010 02:16 PM
Sl2 loses oil Driver23 S-Series Tech 7 12-10-2008 01:43 PM
car loses power saturn_guy S-Series General 6 03-06-2006 09:32 PM
