View Poll Results: What part is faulty
door sensor 1 100.00%
hood/trunk latch 0 0%
BCM 0 0%
key fob 0 0%
Voters: 1. You may not vote on this poll
Old 08-16-2018, 11:37 PM   #1
2006 ion 2 manu
2006 ion 2 manu is on a distinguished road
Devil Possessed Ion, looking for skilled exorcist
I parked my 2006 ion for about 6 weeks. Nobody drove it. Took it to doctors office other day and noticed door locks were trying to relock intermittently while i was driving down the road, also noticed intirior cieling and map lights were coming on and going off intermittently. Parked it when i got home and alarm started going off randomly. I get key fob hit some buttons to make it stop but it keeps doing it. Also noticed while it was parked the interior lights would randomly come on and go off by themselves. I was thinking BCM at first but not really sure. Then I decided to diconnect the battery overnight to try resetting all the elctronics to see if that would fix it, didnt work. I called the dealer, they ran my vin and said theyre were no recalls on my car. Im 90% sure that if i leave the car unlocked the alarm doesnt go off but if i lock it the alarm goes off when parked (makes sense if its a faulty sensor somewhere). The wierd part is the car was fine before I left for vacation, its odd that i come home and its possessed after sitting 6 weeks untouched. Heres a little background, 2006 ion 2 with a 5 speed, 4 door, 150k, im second owner, i bought it off the first owner at 125k, she had the car serviced at the same dealer she purchased it from since new. Serviced reguraly. The car is imaculate/clean/was very lightly used and every thing worked 100% until this. Only modification on whole vehicle is LED headlights /bulbs i installed last winter for better brightness/visability. Only thing I could say bad about the car is i hit a deer with it two summers ago and wrinkled a small portion of the hood near the latch. It was a slow hit about 30 mph, suprisingly little damage never fixed it cuz its hardly noticible. I wondered if theres a hood latch sensor? that would be strange for it to act up two years after the accident. So right now Im going to check all door sensors, hood and trunk latch sensor. As im writing this Im leaning twards faulty door sensor. If nobody has any input im just documenting my case here to mabye help others in the future, will update soon.
Add to 2006 ion 2 manu's Reputation
Rate the quality of this post and help 2006 ion 2 manu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2006 ion 2 manu is offline   Reply With Quote
Old 08-17-2018, 12:03 AM   #2
Default Re: Possessed Ion, looking for skilled exorcist
Original battery? Did you check both battery cables in the trunk, the red cable on the Remote Start terminal next to the engine fuse box. Had the battery and alternator tested at a store seeking car batteries? Is your drive belt loose or tight?
Old 08-17-2018, 12:09 AM   #3
2006 ion 2 manu
Not original battery but its clean and works fine, i did notice its much higher capacity than neened, ill check but i think its 860 cranking amps. Both battery cables in trunk look mint, i took em off to try resseting electronics. Altenator has not been tested but i could put my multimeter on it tomorow see if i get 14v. Belts are fine inder the hood. Ill have altenator and battery tested if i dont find a faulty door sensor tomorow.
Old 08-17-2018, 12:36 PM   #4
2006 ion 2 manu
Happy Re: Possessed Ion, looking for skilled exorcist
Update for anybody with this issue... this morning I found the drivers door sensor was obviously faulty. it was cockeyed in the hole and the slide piece was bent. When i went to remove it the sensor fell into 4 or 5 pieces. Put new one and and issue is resolved.
Old 08-17-2018, 12:45 PM   #5
I mentioned starting with power before going into electronics since one comes first before the other. Screwy power can have an immense effect on everything relying on an even power source.
Your deer story reminded me of a similar incident years ago. My brother borrowed my wagon one hot summer day. He rear ended someone (at low speed), both cars were fine. No damage. He fell asleep without using ac (he's cheap) in the hot weather. About a year later, my radiator sprung a leak. My guess is the light hit was just enough to start a crack but took about a year to develop before replacing it. The wagon was never in an accident before then.
Old 09-03-2018, 04:28 PM   #6
2006 ion 2 manu
Attention Re: its back
So i thought the issue was resolved because it went away for a few days. But all the symptoms are back, I checked all the other door sensors and nothing seems wrong. I had some other wierd symptoms as well, new ones, when i started the car the other day the instrument cluster was flickering the whole drive. And the right front turn signal went out then came back the next day. litterally just a bunch of starnge wierd symptoms.
Old 09-06-2018, 02:09 PM   #7
hudypete1
2007 ION-3 Sedan
Where do you live? It seems that there could be an intermittent short, possibly made worse due to summer humidity.
What things are giving funky readings/operation now?
What things are clearly working perfectly without problems?
Peter in Lansing MI
current cars:
94 SW2 (White, automatic)
99 SL2 (Silver Plum, manual)
99 SL2 (Dark Blue, manual)
04 Ion 3 (Berry Red, 2.0L automatic)
07 Ion 3 (Cypress Green, 2.4L, manual)
Add to hudypete1's Reputation
Need Help: My SL2 Is Possessed mbratch S-Series Tech 23 08-14-2008 02:32 PM
L200 possessed glgeek L-Series Tech 6 07-27-2007 08:55 PM
Car is possessed... fan keeps blowing, sometimes. c5_droptop S-Series General 1 06-26-2006 11:25 AM
HELP!!! Car is Possessed!!! Please help! Lizzy S-Series Tech 5 04-26-2006 03:12 PM
Help - car possessed vaughna L-Series General 1 07-03-2005 07:02 PM
