Old 12-17-2013, 03:33 PM   #1
coastiejoe
coastiejoe is on a distinguished road
Default 2002 saturn sl2 - heater motor
Heater motor will not turn on. I have replaced the heater motor, fuse, relay, resistor, I have checked the fuse under hood, replaced heater switch and there is still no power to the heater motor with a volt meter. Anyone have any ideas what I should do now??
Add to coastiejoe's Reputation
Rate the quality of this post and help coastiejoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coastiejoe is offline   Reply With Quote
Old 12-17-2013, 03:59 PM   #2
Default Re: 2002 saturn sl2 - heater motor
Here's a wiring diagram to study. Hope this helps.
Old 12-17-2013, 04:27 PM   #3
climbski
climbski has a spectacular aura aboutclimbski has a spectacular aura about
2000 SW2
1999 SW2
Fusebox connections gone bad? Switch?
Add to climbski's Reputation
Rate the quality of this post and help climbski reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
climbski is offline   Reply With Quote
Old 12-17-2013, 04:33 PM   #4
GeekOnTheHill
GeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the rough
GeekOnTheHill's Avatar
Use the diagram and start at the beginning, checking power at each point. When you stop getting power, you've isolated the problem.
Unfortunately, that's really what it comes down to. If it's not blowing fuses, then it's probably a loose or corroded wire or connection somewhere. You just have to narrow it down. Good luck.
-Richard
Add to GeekOnTheHill's Reputation
Rate the quality of this post and help GeekOnTheHill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GeekOnTheHill is offline   Reply With Quote
Old 12-21-2013, 03:39 PM   #5
coastiejoe
I have started my troubleshooting and I have a couple additional questions....
1) There is a ground strap located on the passenger side near the fuse box support that is disconnected. Do you think this could be the problem or know where it goes?
2) The next question is, the heater relay is chattering. Does anyone know what could cause this and if these two things are related?
Thank you in advance for your assistance.
Joe
Old 12-21-2013, 03:50 PM   #6
1) Ground strap should be on the stud that's probably hidden under crud or previous work broke out of the car. While not 100% required, the electronics are fairly ground system sensetive so it'd be a very very good idea to figure out a grounding location (not on the engine) for it.
2) Not likely to be directly connected to the ground strap but if the previous owner left that wire disconnected..what else did they miss? example: My dad got a '98 K1500 w/plow for $800 (truck is worth $1200 on it's own) due to it not running with the MM plow plugged it...they were morons with electrical, I just had to rewire it properly without buying anything or using any "new" parts to get it 100% fixed.
Old 12-26-2013, 07:32 PM   #7
coastiejoe
I was trouble shooting my wiring today, I found that the purple wire behind the fuse box has burned. I have pulled it apart and saw that the flat spade was melted. My question is how can I pull that purple wire out of the fuse box to replace it. It is the female side that needs to be replaced.
Old 12-26-2013, 07:44 PM   #8
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Are you talking about the fuse panel on the side of the console?
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 12-26-2013, 07:56 PM   #9
coastiejoe
yes on the passenger side
Old 12-26-2013, 08:16 PM   #10
caveeagle
caveeagle's Avatar
You could easily get a replacement section of wire with the proper metal clip from a U-pull parts car. Hopefully, you did not melt too much of the plastic fuse panel housing and can repair it with some doner wiring.
I am sure it will not be too easy to get behind that panel. ..... But you did get in there far enough to at least find this issue.
Mark
Old 12-27-2013, 12:07 PM   #11
trottida
trottida's Avatar
deleted post.
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Heater control valve 2002 vue 3.0 iamjim Vue Tech 7 12-12-2012 09:37 PM
2002 Saturn SL2 133410 miles smoking and not allowing oil into motor saturnsc001 S-Series General 3 10-27-2012 12:04 PM
2002 SC2 Heater Blower Noise jb12 S-Series General 7 12-12-2009 10:44 AM
Heater Blower motor Resistor Location Rivernut L-Series Tech 3 08-01-2007 12:21 AM
heater fan motor interchangebility 92[SL2] S-Series Tech 0 07-12-2007 10:02 PM
