Old 07-08-2019, 07:59 PM   #1
Twinturbo
Twinturbo is on a distinguished road
Default Disconnect injector and/or coil sl1 w bad cylinder
Hi,
Need some good solid advice, Have a 99 SL1 that is biting the dust due to a bent valve and is not worth fixing due to the age and mileage 321,000+. I have to drive it as is for now as I look for another car and I need to know if I should disconnect the injector to*that cylinder and anything else like a coil wire if possible. My mechanic said drive til it dies and I may do that hence the question. He tapped the bent valve lightly to insure it would not fall into the cylinder. AND after posting a question a few days ago about if there is a hotter range plug for my car with little response can anyone confirm that no such plug exists? Thanks!
Add to Twinturbo's Reputation
Rate the quality of this post and help Twinturbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twinturbo is offline   Reply With Quote
Fuel injector location / cylinder association kewlpop S-Series Tech 11 01-10-2019 01:45 AM
Dead Cylinder, Fuel Injector or Coil?? DMC24guy S-Series Tech 10 04-09-2015 11:37 AM
96 SC2 Bad injector or dead cylinder eggbirtt S-Series Tech 1 02-02-2008 01:24 PM
What do you think? Failing fuel injector, or coil/arcing problems? chinch33 S-Series General 5 09-21-2005 05:35 PM
Do I disconnect all the low voltage wires from coil pack to do an compression check? rwagen Miscellaneous Tech 3 11-03-2002 03:41 PM
