Old 06-23-2018, 08:50 AM   #1
Cavell
Cavell is a jewel in the roughCavell is a jewel in the roughCavell is a jewel in the rough
2004 VUE 3.5L
2003 VUE 3.0L
Default wont go in gear
stuck in neutral. cannot move shifter into any gear. sound like master cyl/slave cyl issue?
Add to Cavell's Reputation
Rate the quality of this post and help Cavell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-23-2018, 09:28 PM   #2
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Default Re: wont go in gear
Does the clutch fell normal??
If you shut the engine off, will it shift into gear??
Add to waiter21's Reputation
Old 06-24-2018, 09:47 AM   #3
Bruce Rock
Bruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the rough
2000 SL2
2006 VUE 2.2L
What does your clutch fluid look like?
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-24-2018, 10:55 AM   #4
Cavell
2004 VUE 3.5L
2003 VUE 3.0L
Not mine. Seller says it will not go into gear with motor off. Fluid is full. No leaks. Was driving and it got harder to shift and than it would not go into any gear. He said pedal feels like nothing. No effort? He said he had shift cables replaced last yr? Not clear on shifter cable parts. I assume it's not a cable issue if it won't go in gear?
Old 06-24-2018, 03:00 PM   #5
RGRG68
RGRG68 has a spectacular aura aboutRGRG68 has a spectacular aura aboutRGRG68 has a spectacular aura about
2004 VUE 2.2L
My guess is slave cylinder. (clutch feels like nothing) seems to mean no pressure. May also be a large air bubble (from air coming into the slave ) entered the line. First thing I would do is bleed the slave and then the master and see if it gets better. If it does, may mean bad slave. Harder and harder to shift may mean the pressure plate was slowly collapsing.. then it gets put in N by the driver, and can't get back in a gear.
Add to RGRG68's Reputation
Rate the quality of this post and help RGRG68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RGRG68 is offline   Reply With Quote
Old 06-24-2018, 09:23 PM   #6
waiter21
2003 VUE 2.2L
not sure what that means?? When pressing the clutch pedal, does it fell normal, as in a little resistance. OR does the clutch go to the floor with almost no resistance, OR is it very hard and doesn't move at all??
My initial thoughts are clutch.. HOWEVER, It could be a bad master cylinder
Wont go into gear. Richspen S-Series General 9 09-04-2012 08:19 AM
car wont go into gear rxzone S-Series Tech 1 08-22-2007 08:09 PM
sw2 wont go into gear!!!!help!!! travisr_528 S-Series Tech 7 09-22-2006 10:05 PM
94 sl1 wont go into 1st or 2nd gear k00_00b L-Series General 2 12-08-2004 06:52 PM
Wont go in 2nd Gear! anniesmallwood S-Series Tech 2 11-15-2002 10:42 PM
