Old 01-21-2015, 06:34 PM   #1
Jeeprz!
Jeeprz! is on a distinguished road
Default Lower trans line removal, luckly the metal line didn't twist
- instead the fitting in the radiator tank did.
Now I can add a radiator to my never ending parts list. Grrr
Anyway since I have to pull it out and of course drain it, I might as well replace the lower rad hose and thermostat.
I would prefer to go with the all aluminum AMR one, but I can't justify the $300 cost for my daily driver (that is, daily driver if I ever get the damthing back on the road, lol) so it will probably be the Silla I read about on here.
I thought I recall reading on the board the the OEM thermostat kit Part #21006335 that are made in Germany are the way to go but about impossible to find anymore.
Well I found one with the correct part number on GMparts direct, but now I'm wondering if it will actually be the German made one Richpin recommended in his YouTube video when it get's delivered.
Also I plan to pull the old thermostat, do a flush with just distilled water (Had orange Dexcool in it) and refill with 1 gal 100% Prestone universal and top it off with distilled water per OldNuc's recommendation.
I didn't have any heating or cooling issue's before so I think this seems like a solid plan.
"Officer, turning on your lights and siren just because you lost the drag race is just poor sportsmanship."
"Turtle" the Green 1998 SC2 Auto DOHC 160k that doesn't burn any oil!
Add to Jeeprz!'s Reputation
Rate the quality of this post and help Jeeprz! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeeprz! is offline   Reply With Quote
Old 01-21-2015, 06:52 PM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: Lower trans line removal, luckly the metal line didn't twist
And if your trans cooling lines are all rusted at the ends, you can add 2 of those to your never ending list.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 01-21-2015, 06:59 PM   #3
Jeeprz!
Yep, the lower was rusted to a blob on the rad end, that's what I was trying to remove and replace when this happened.
Old 01-22-2015, 03:29 PM   #4
Jeeprz!
Would it be a good idea to use the white teflon tape (plumbing tape) on the trans cooling line fittings to the new rad, or is that a bad idea?
Old 01-23-2015, 12:58 PM   #5
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
No need for the white teflon tape. The key is to not reef on the fitting. It needs to be tight, but not so tight that it breaks the rad coming out.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lower transaxle cooling line replacement Jeeprz! S-Series Tech 4 01-19-2015 12:35 AM
Leak from metal heater return line ifsaturn S-Series General 13 08-12-2014 05:31 PM
replacing the lower AC line Mom'sSaturn L-Series Tech 7 09-01-2012 02:48 PM
Replacing lower brake line fittings? PlasticCarsRock S-Series Tech 2 09-05-2010 02:01 AM
Replacing Short Hose From Reservoir to Metal Line The Critic S-Series Tech 11 12-21-2008 02:01 PM
