Old 01-24-2007, 07:49 PM   #1
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
Wrench O2 sensor question
Hey,
Back in the day I ghetto-rigged a one-wire O2 sensor in place of a heated 4 wire one. I've been working hard to get my car back to perfect running condition and the only thing left that sets off the SES light is the O2 sensor heater circuit.. because there is no heater.
The sensor itself works great, tested with Autotap and voltage jumps around within proper range. Just need to know what the resistance should be on the O2 heater circuit so I can stick a resistor in there and call it good. I've seen it somewhere before, but searching the forums turned up nothing.
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 01-24-2007, 07:58 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: O2 sensor question
Start at one ohm. That's 12 watts of power at 12 volts. Good for a tiny heater.
Add to eljefino's Reputation
Old 01-24-2007, 08:07 PM   #3
Or try Googling heated O2 sensors to find the specs for the heater and output voltages. Google is your knowledge base.
Old 01-24-2007, 10:57 PM   #4
DonP
WARNING: One (1) ohm at 12 volts is more like 144 watts, (12 amps times 12 volts) but given that a car electrical system is closer to 14 volts it is more like 190 watts, if the wires are large enough to can carry the 13-14 amps current without melting.
Add to DonP's Reputation
Old 01-24-2007, 11:09 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Originally Posted by plastic torpedo View Post
Hey,
buy a four wire heated o2 sensor or an o2 sim www.o2simulator.com
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-25-2007, 12:14 AM   #6
plastic torpedo
2000 SL2
1994 SC2
I don't think I like that alternative.. I bought the one wire sensor to save money in the first place.
Google is indeed my friend though:
Exact heater resistance specifications may vary depending on the vehicle and sensor location. Heater element resistance should be about 4 to 7 ohms for a sensor at ambient temperature.
Old 01-25-2007, 01:05 AM   #7
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
someone donate a used 4-wire sensor to this guy.
Add to sc2dave's Reputation
Rate the quality of this post and help sc2dave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2dave is offline   Reply With Quote
Old 01-25-2007, 05:27 AM   #8
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
The price difference is negligible compared to the cost of possible damage and loss of fuel milage due to "ghetto rigging"... I think the universal 4 wire is roughly $30.....
If you are "working hard to get your car in perfect running condition", do it right, or leave it the way it is. But that is just my opinion....
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-25-2007, 08:03 AM   #9
BarnOwl
BarnOwl's Avatar
What ^^^^ he said with one exception. Bigdaddy I certainly bow to your greater knowledge here but, I don't think that the heated O2 sensor will affect mileage or performance. That would be the rear O2 sensor and I believe that is only used to check the cat. Please correct me, if I'm wrong.
Add to BarnOwl's Reputation
Old 01-25-2007, 09:32 AM   #10
DonP
If the sensor is heated, that is for a reason. Lack of heat will likely result in it operating at a cooler than design temperature and its output may be incorrect.
This inaccurate output could end up setting other OBDII codes, if not one for the O2 sensor heater circuit or O2 sensor response. The cost in time to chase down another code probably exceeds the extra cost for the right sensor.
And depending on where you are located, the car might fail inspection if the mod is detected.
BTW: the http://www.o2simulator.com/27978.html page indicates that a 20 ohm, 20 watt resistor can usually be used to simulate the heater circuit. They sell them for $5. They also state that GM cars do not monitor the heater circuit. If that is the case for the s-series, an open heater circuit by itself would not throw a code.
You pays your money and takes your chances.
Old 01-25-2007, 09:41 AM   #11
NoRemorse
NoRemorse is on a distinguished road
NoRemorse's Avatar
PM me, I have an extra 4 wire sensor I may be willing to donate, but it has been cut, so you would have to solder it in
Add to NoRemorse's Reputation
Rate the quality of this post and help NoRemorse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NoRemorse is offline   Reply With Quote
Old 01-25-2007, 10:05 AM   #12
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
The reason for the heated sensor is to put the car into closed loop sooner and keep it there. Non-heated sensors relied on exhaust gasses to heat the sensor to operating range. This could easily take a few minutes of driving time to happen. Also, when the engine was idling, the exhaust heat was insufficient to keep the sensor operating, thus returning the car to open loop.
So there are efficiency and performance gains to be had with the heated sensor, but it would be difficult to prove it. It keeps your engine in closed loop operation to satisfy emission requirements.
No, you do not have to run a heated sensor, but if that's how your car came, there's really no reason not to keep it as a heated sensor.
Old 01-25-2007, 10:21 AM   #13
BarnOwl
BarnOwl's Avatar
Will the rear sensor output keep it from going into closed loop??? I would think that once the front one is heated and the engine was up to temperature, it would go into closed loop and stay there no matter what was going on with the rear sensor. Please understand, I'm not arguing here. I really would like to know.
Old 01-25-2007, 10:24 AM   #14
NoRemorse
NoRemorse's Avatar
The rear sole purpose is to ensure that the catalytic converter is functioning and has no role in engine performance and operation.
Old 01-25-2007, 10:42 AM   #15
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
True dat! Even if the rear sensor fails completely, you and the engine would never know it but for the MIL being on.
Old 01-25-2007, 02:50 PM   #16
BarnOwl
BarnOwl's Avatar
That's what I thought. It kind of threw me when Gerry came across with that not going into closed loop. That's why I asked.
Old 01-25-2007, 03:06 PM   #17
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
What Gerry said is correct. An o2 sensor depends on heat to operate. Somewhere around 700 degrees. A heated o2 sensor gets hot quicker allowing the system to go to closed loop sooner, conserving fuel and reducing emissions.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 01-25-2007, 04:20 PM   #18
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
BarnOwl wasn't confused about that, but that I wasn't specific about sensor 1 and sensor 2.
Old 01-25-2007, 06:08 PM   #19
NoRemorse
NoRemorse's Avatar
I don't really remember what my SL had on it, but if the rear has a heater (4 wire) why don't you just swap the 2. It's not as imperative to have the rear heated (although it would still throw a CEL)
Old 01-25-2007, 07:11 PM   #20
DonP
The main reason to ensure the ECM thinks there is a proper sensor in back is to prevent it setting code for the sensor and/or CAT. Getting used to the presense of the SES due to a false code could mask a real code of some significance. Passing emissions inspection, wher applicable, helps as well.
O2 Sensor Question Khellendrose S-Series Tech 6 03-16-2008 02:02 AM
02 sensor question GRAFIX111 S-Series Tech 5 05-21-2007 09:32 AM
O2 Sensor question nuwt S-Series Tech 2 11-18-2005 10:13 PM
02 sensor question... jefferson70 Miscellaneous Tech 3 09-19-2003 03:55 PM
Sensor Question? Onewest Miscellaneous Tech 4 02-27-2003 11:37 AM
