Old 01-08-2005, 06:31 PM   #1
folkindrummer
folkindrummer is on a distinguished road
folkindrummer's Avatar
Default removing the antenna?
I would like to unscrew the antenna and was told that I could do this very easily... well, after spinning it endlessly it's still attached.. is there something I'm missing? How the heck do I get the antenna off?
2004 FWD, 5 Spd Manual w/ Sport Package - Black
2003 FWD, 5 Spd Manual - Silver
Add to folkindrummer's Reputation
Rate the quality of this post and help folkindrummer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
folkindrummer is offline
Old 01-08-2005, 06:36 PM   #2
robert_vue
robert_vue is on a distinguished road
robert_vue's Avatar
Default Re: removing the antenna?
When I saw this, I was just going to say unscrew it. On a previous car, it was loose, and just tightened it with vice grips, but I guess removing it must be a different story. After you loosened it, were you at least able to tighten it back up?
Robert R.
03 VUE: Oct 15, 2002 - Dec 5, 2004 R.I.P.
Add to robert_vue's Reputation
Rate the quality of this post and help robert_vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robert_vue is offline
Old 01-08-2005, 07:20 PM   #3
SkyVue
SkyVue is on a distinguished road
2003 VUE 2.2L
Question Re: removing the antenna?
So I take it the antenna can't be removed and re-wired. I was thinking of removing mine an putting a VW fuba antenna like the Acura MDX Can this be done? what do you guys think? I think it would look really good.
Add to SkyVue's Reputation
Rate the quality of this post and help SkyVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SkyVue is offline
Old 01-08-2005, 07:20 PM   #4
folkindrummer
didn't try...
Old 01-08-2005, 08:45 PM   #5
scotted73
scotted73 is on a distinguished road
scotted73's Avatar
2007 Outlook XR
2002 L-Series 3.0L Wagon
A 7mm open ended wrench fits the non-round part of the antenna to remove it. It basically screws on. --See image...this is the part you are describing?
It may have been overtorqued and stripped somehow. They ship [the car] without the antenna attached. Part of the Pre-Delivery Inspection by the techs is to attach it.
Add to scotted73's Reputation
Rate the quality of this post and help scotted73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scotted73 is offline
Old 01-08-2005, 08:50 PM   #6
SkyVue
2003 VUE 2.2L
Yes that is the part. I would like to fill in the hole that is left and paint it to match the body and put the antenna on the roof like the Acura MDX
SkyVue is offline
Old 01-08-2005, 08:57 PM   #7
scotted73
scotted73's Avatar
2007 Outlook XR
I was thinking of using the antenna and associated parts from a L-Series Wagon, since it is already configured for placement on the rear roof. I haven't priced the parts new, I'd guess that a junk yard would have a L-Series Wagon that could be cannibalized.
Old 01-08-2005, 10:17 PM   #8
folkindrummer
Yeah, that's the part I was unscrewing... but it just kept spinning. I scored it at one point to make sure I wasn't loosing my mind and the line didn't move. I took off the rubber gasket and the plastic housing looks cracked. Will it pull out?
Old 01-08-2005, 11:26 PM   #9
scotted73
scotted73's Avatar
2007 Outlook XR
It's certainly worth a shot pulling on it--the threads on the antenna base are a seperate piece from the antenna base itself. It also appears to be the same case with the antenna too. Maybe some WD-40 may help?
If all else fails, you may end up removing the panel to access the underside.
Old 01-11-2005, 10:58 PM   #10
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
My antenna always gets loose, I can unscrew it with my fingers without a problem. I don't know why, but I never thought of taking a wrench to it. *duh*
Add to Dante's Reputation
Rate the quality of this post and help Dante reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dante is offline
removing the antenna wire from radio fosgate3 Ion Tech 4 12-03-2006 12:32 AM
Removing radio antenna shagdrum S-Series Tech 8 11-04-2006 10:48 AM
removing/replacing stock antenna... 12:oc7ock S-Series General 3 06-19-2006 10:26 PM
removing the antenna defy69 Ion General 2 06-21-2005 01:31 PM
