Old 12-12-2004, 12:12 PM   #1
coolgreany
coolgreany is on a distinguished road
coolgreany's Avatar
2002 VUE 3.0L
Default Rust colored on outside of plug and plug boot
Just passed my 3-year warranty date this week and have 27K on the 2002 SL2.
I was checking the plugs last week and noticed the passenger side cylinder (# 1?) had what seemd to be a rust colored coating on the outside of the plug boot and the base of the plug nut. What could this be and the possible cause? The only thing I can think of is that water got down there somehow but from rain or engine wash or coolant?
02 VUE Auto AWD-63k-Florida
02 SL2 Manual -76K, Germany
00 SL2 Auto-90K-failed emissions, Portland, OR
99 SL2 Auto-115K-aging, Portland, OR
91 SL1-Stolen 03, 113K
96 SL1-Totaled 02, 86K
Add to coolgreany's Reputation
Rate the quality of this post and help coolgreany reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coolgreany is offline
Old 12-12-2004, 01:19 PM   #2
Luke
Luke's Avatar
Default Re: Rust colored on outside of plug and plug boot
I may be reading into what you're saying >>the porcelain part of the plug << is showing "rust" coloration, suggests evidence of oil getting into the plug well. When one removes their plugs, that is one of the first things which should be checked. For that is one of the primary visual results. With this in mind, your valve (cam) cover gasket is leaking oil into the plug well. As has been considerably commented, this is a common issue with Saturns.
Add to Luke's Reputation
Luke is offline
Old 12-12-2004, 03:36 PM   #3
coolgreany
coolgreany's Avatar
2002 VUE 3.0L
Yes, the outside part of plug but around the metal nut base that the plug socket turns. If it's the cam cover would the consistency be oily? This was pretty dry which made be think it was more a rust.
Old 12-12-2004, 04:54 PM   #4
Luke
Luke's Avatar
Yes ! The consistency would be oily, not on the plug, but at the base, in the well. Doesn't mean to be much; could even be crusty
Luke is offline
Old 12-12-2004, 05:11 PM   #5
Dr. Bob
Dr. Bob is on a distinguished road
If it is rusty, but not oily, most likely it's water in the plug wells.
The only time I've had this happen was when somebody (mis)used a pressure washer to clean the engine and engine bay. That's not to say water could get in there via other means.
Add to Dr. Bob's Reputation
Rate the quality of this post and help Dr. Bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr. Bob is offline
Old 12-12-2004, 06:00 PM   #6
coolgreany
coolgreany's Avatar
2002 VUE 3.0L
I do think it's a water origin. I'll check it in a week or two to see if it returns.
Old 12-14-2004, 03:26 AM   #7
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
FWIW, I had similar symptoms when I bought one of our Saturns from Carmax several years back. Turned out they had pressure cleaned the engine and water got around the plug boot. I was changing plug wires anyhow and decided to just put in a fresh set of plugs, too. Never had any problem.
Retired July 2018
1999 SC2 - 435,023 miles
1999 SL2 - 196,163 miles
Previous
1996 SC2 and 1999 SL2
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-15-2009 12:31 AM
White Ashy Deposits on Spark Plug Wire Boot The Critic S-Series Tech 2 03-25-2009 08:44 AM
Plug-In Vue Hybrid Previewed at "Plug-In 2008" Convention Charlie Vue Green Line 0 08-28-2008 09:15 PM
Blockheaters: To plug or not to plug? 99SC1-R S-Series General 20 12-05-2003 09:16 PM
plug wires stuck on plug greasynails Miscellaneous Tech 6 07-25-2003 03:49 PM
