Old 11-11-2003, 01:56 AM   #1
Lurker1999
Lurker1999 is on a distinguished road
1993 SC2
Wrench Replacing G1 SC2 Headlights (Pop-Up)
Parts needed:
Two H4666 sealed beam headlights
T-15 torx bit
1/4 ratchet with 2" extension
phillips screwdriver
penetrating oil
magnetic pick-up (optional)
Chilton's description of the process was a bit confusing in my opinion.
1. Raise headlights by turning them on the full 3 clicks, then turning them off
only 2 clicks (lights stay up).
2. Raise hood.
3. Remove 3 torx fasteners from the plastic moulding around the light. Two are
on the outer side, one on the inner. Use the extension to help your ratchet clear
your paint.
4. Remove 4 phillips screws from the metal bracket physically holding the light
in place. You may need to spray pentrating oil on these screws and push hard to
avoid stripping them in the process.
5. Remove the bracket and pull the headlight carefully away from the holder.
6. Disconnect the electrical cabling in the back.
7. Clean electrical connections as needed and put your new light in.
8. Assembly is the reverse.
Caveat: If you drop one of the two screws on the bottom of the metal bracket from
step 4 you'll either need a magnetic pick-up or screwdriver to lift them back out.
There isn't enough clearance for your hand to fit below the headlight without
removing something else.
Time needed: 15 minutes.
93 SC2a 69k
Add to Lurker1999's Reputation
Rate the quality of this post and help Lurker1999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lurker1999 is offline
sc2 pop up headlights sl2collector S-Series Tech 2 09-09-2008 02:03 AM
1996 SC2 Pop-up Headlights jebellon S-Series Tech 1 07-15-2008 12:46 PM
1996 SC2 Pop-up Headlights jebellon S-Series General 2 07-11-2008 10:49 PM
1996 SC2 Pop-up Headlights jebellon S-Series General 3 07-10-2008 08:18 PM
sc2 pop UP headlights,,PARTS fastion Classifieds 0 03-14-2006 12:44 AM
