Old 11-04-2019, 03:29 AM   #1
leviklump1133
leviklump1133 is on a distinguished road
Default Headliner removal and installation
pretty simple job that will take no more then 2 hours!
1999 sl1 saturn
i used 3m 90 adhesive spray and it worked perfectly with a great bond..
put both seats all the way down.
Remove the dome light *richpin
remove the two sunvisors with a PH screwdriver.
remove the handles on the roof with a 7mm ratchet.
remove the side panels that are held in with plastic clips.
remove the brake light panel that is held in with clips.
remove the seatbelt buckle with a torque 50 bit.
you can then take the headliner out, it fit perfectly out of the rear doors of the sedan model, if you own a coupe you might need to remove it through the trunk.
i then used a metal and plastic wire brush to clear off all of the old foam/headliner.
slowly worked from one end to the other going in 20% increments, using a plastic card to get out all of the wrinkles.
BOOM, ITS DONE. as easy as that.
installation is the same as the removal, in reverse order.
(*richpin, he has a good video on youtube showing how the dome light is correctly removed)
Add to leviklump1133's Reputation
Rate the quality of this post and help leviklump1133 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
leviklump1133 is offline   Reply With Quote
Old 11-04-2019, 03:34 AM   #2
leviklump1133
Default Re: Headliner removal and installation
unfortunately the forum will not let me post the same pictures twice, you can see the final result on the " what did you do to your saturn today" thread, on page 315 post 6297
if someone with over 15 posts, could post the link to the pictures i would greatly appreciate it.
Old 11-04-2019, 07:35 AM   #3
Waiex191
Waiex191's Avatar
Nice job!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-04-2019, 10:34 AM   #4
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
Haha! Great idea. When I did it I bought some generic cheapest material that happened to be the perfect color match.
Add to Hiisi's Reputation
Rate the quality of this post and help Hiisi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiisi is offline   Reply With Quote
Old 11-04-2019, 01:41 PM   #5
RobertGary1
Its super easy in the coupe because the door is much bigger.
-Robert
Vue Headliner Removal, anyone know how? fireman5031 Vue Tech 7 11-11-2016 11:04 PM
8 years after headliner installation--- info JerryHughes S-Series General 25 09-25-2016 02:12 AM
Third-gen SC headliner removal tip theunpaidBill S-Series General 3 09-23-2016 12:14 PM
Headliner Removal Pokerking1993 S-Series General 2 06-04-2013 12:00 PM
03 Headliner removal VTchemist Vue Tech 4 10-06-2011 08:00 PM
