Old 11-03-2019, 11:39 AM   #1
changeling616
changeling616 is on a distinguished road
Default 2001 SC2 Coupe- where to put in transmission fluid?
This project is weeks old.
Had to disconnect the transmission fluid line from the radiator, and in process lost the transmission fluid.
Now everything is back together, but I don't know where to put IN the transmission fluid.
I see where to put in engine oil, brake fluid, power steering fluid, coolant/antifreeze... but where for the transmission fluid?
Add to changeling616's Reputation
Rate the quality of this post and help changeling616 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
changeling616 is offline   Reply With Quote
Old 11-03-2019, 11:51 AM   #2
Waiex191
Waiex191's Avatar
Default Re: 2001 SC2 Coupe- where to put in transmission fluid?
It goes in the dipstick tube on an automatic. They make special funnels for it.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-03-2019, 12:10 PM   #3
changeling616
Thanks. I was wondering if that was it.
Old 11-03-2019, 01:16 PM   #4
onlinebiker
Pour slowly in small amounts.
If you pour in a large amount - pressure builds up and it will burp back - puking ATF directly on the exhaust manifold....
Uness you need to fog for mosquitos.......
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-03-2019, 02:58 PM   #5
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Originally Posted by onlinebiker View Post
...Uness you need to fog for mosquitos.......
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-04-2019, 10:41 AM   #6
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
Just add Lucas additive. It comes with the special pipe on the bottle that fits the dipstick. And you need Lucas additive anyways, don't you?
Add to Hiisi's Reputation
Rate the quality of this post and help Hiisi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiisi is offline   Reply With Quote
Old 11-04-2019, 11:07 AM   #7
Waiex191
Waiex191's Avatar
If you believe in that sort of thing! I'd rather believe in extraterrestrials.
Bryan Cotton
Old 11-04-2019, 11:21 AM   #8
Hiisi
Hiisi's Avatar
Well, it sort of worked for me. Before I had to replace the valve body
But I also believe in the radiator stop-leak and engine gasket repair fluids
Can I use transmax multivehicle to replace transmission fluid in 2001 manual sl2 vikasevan S-Series Tech 29 02-17-2018 10:06 AM
2001 SC2 transmission fluid question... gua742 S-Series Tech 8 02-25-2012 10:40 PM
2001 LW200 manual transmission fluid change? dbswayne L-Series Tech 15 02-12-2012 06:35 PM
Manual Transmission Fluid On 2001 SL1 motoboymatt S-Series Tech 5 03-16-2010 01:41 PM
Transmission Fluid - 2001 Sc2 01SIlverSc2 S-Series Tech 12 05-03-2007 01:50 PM
