Old 10-28-2019, 05:28 PM   #1
racecalf
racecalf is on a distinguished road
Default Door wires
Old door wouldn’t roll down or up, got new door and forgot to unhook battery before cutting the wires. Hooked up the new door and the door still won’t roll down or up and now my power locks don’t work. Double checked all the wiring and the fuses and swapped out relays with used ones from the junk yard still nothing. What could it be? 1998 Saturn sl
Add to racecalf's Reputation
Rate the quality of this post and help racecalf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
racecalf is offline   Reply With Quote
Old 10-29-2019, 09:15 AM   #2
trottida
trottida's Avatar
Default Re: Door wires
Did you check the switches? Does it not work with both the central switch pod and the door switch? Is there power to the connector?
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
2006 Vue rear door drivers side passenger door won't open. khelton79 Vue Tech 1 11-03-2014 03:48 PM
Which wires to cut on the door lock? Gromit S-Series General 4 08-24-2011 02:37 PM
Replace electric door lock switch on drivers door-1999 SW2? Reader S-Series Tech 2 12-04-2010 09:13 PM
97 SW2 where do these wires go? are they ground wires? GQROD S-Series Tech 10 06-27-2009 09:12 AM
8.5mm wires vs. 10mm wires BobDobbs Mods and Performance 7 11-20-2001 09:09 PM
