Old 07-22-2003, 08:49 PM   #1
greasynails
greasynails is on a distinguished road
Default plug wires stuck on plug
I have two Saturns and a 92 Chev Lumina APV with a 3.8 V-6. I've never had trouble getting wires off the plugs on my Saturns, but the APV wires are about impossible to get off. I know this is Saturn forum (I haven't had much luck on the Chevy forums). - I just wondered, do any of you have any ideas of how I can get those wires off, - w/o pulling the whole engine?!
Thanks in advance
Add to greasynails's Reputation
Rate the quality of this post and help greasynails reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greasynails is offline
Old 07-22-2003, 11:36 PM   #2
tightsaturn96
tightsaturn96 is on a distinguished road
tightsaturn96's Avatar
Default
If they have been on there for a long time you may not be able to get them off at all--they may have stuck/melted/deteriorated to the plugs too much . I once was helping someone change some plug wires on a car whose wires hadn't been removed in years=same problem as yours. To make a long story short we cut the wires and used a knife to cut the boot away from the plug till we got enough off to get the spark plug socket on there. Buy some of that boot protector stuff (like $1) so it won't happen again.
Add to tightsaturn96's Reputation
Rate the quality of this post and help tightsaturn96 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tightsaturn96 is offline
Old 07-22-2003, 11:43 PM   #3
Dr. Bob
Dr. Bob is on a distinguished road
Default
Use boot release silicone grease on the plug insulators the next time and they'll come off easily.
Add to Dr. Bob's Reputation
Rate the quality of this post and help Dr. Bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr. Bob is offline
Old 07-23-2003, 12:34 AM   #4
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
Default
If you havent tried so already, a set of plug boot pliers might also help to grab onto the boots.
Add to MaxSL2's Reputation
Rate the quality of this post and help MaxSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MaxSL2 is offline
Old 07-23-2003, 09:42 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
twist them and pull.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 07-25-2003, 03:00 PM   #6
greasynails
Default
Thanks for your advice, everyone. I ended cutting the wires above the boot, sliding the metal heat sheild off, and then cutting the boot off. Since they are on the far bank it involved laying on the engine and doing everything by feel, - but I am thankful to have the old wires off and new plugs and wires on!
Old 07-25-2003, 03:49 PM   #7
tightsaturn96
Default
Did you use boot protector gel so it won't happen again?? If not, go get some and put it on soon.
Plug wires DarrylLeeOHS30 S-Series General 7 12-11-2005 10:42 AM
which plug wires? Jaded Mods and Performance 11 01-12-2004 03:26 AM
Plug Wires? Chris93SL2 Mods and Performance 9 04-09-2003 11:41 AM
Best plug wires? 94sc293sl1 S-Series Tech 9 03-20-2003 03:15 PM
Plug wires do what? SL2Fan Mods and Performance 3 07-03-2001 06:43 PM
