Old 02-20-2016, 01:53 PM   #1
pikman
pikman is on a distinguished road
Default Cup holder removal
I have a 2008 Saturn Astra, and would like to now if it is possible to remove the cup holder, that sticks out of the front/middle of the rear seat. You have to push the front of it, and it slides out, but something was spilled on it, and it sticks, and I would like to clean it.
Add to pikman's Reputation
Rate the quality of this post and help pikman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pikman is offline   Reply With Quote
Old 02-21-2016, 12:52 PM   #2
nicolas_p
nicolas_p has a spectacular aura aboutnicolas_p has a spectacular aura about
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Default Re: Cup holder removal
If I remember correctly and Phatfire6 may want to confirm. The rear cupholder is simply clipped in from the top and bottom to a metal sleeve which acts as the support. Kind of like the rear interior lights on the roof. Should be able to shove something in the top and bottom to release the clips. Might also be easier to work on if you remove the whole rear seat which is done by pulling on the two taps located at the bottom of the bench, pull the taps out towards you and lift the seat up and out at the same time. The tabs are sometimes difficult to remove and require a good amount of pressure to be applied to them.
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Eibach Sportline, Whiteline BHR75Z swaybar and EBC Rotors
CD30 Mp3, Insignia jets, vxR surround, sharkfin antenna, Spoiler, Tint
Add to nicolas_p's Reputation
Rate the quality of this post and help nicolas_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nicolas_p is offline   Reply With Quote
Old 02-21-2016, 01:38 PM   #3
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
You have to remove the seats to release the cartridge that holds everything together. Once the seat is removed, you press through the foam from underneath while pulling the cartridge out.
Also, when removing the seats, put pressure down on the seat and then pull the tabs forward to get them to release. After they are pulled forward, lift up on the seat to release it from the clip.
Add to phatfire6's Reputation
Rate the quality of this post and help phatfire6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phatfire6 is offline   Reply With Quote
Old 03-11-2016, 04:28 PM   #4
pikman
Thanks for the help. Was able to fix it.
(sorry for the late reply...I thought my first response had gone through, but i guess not.)
Removal of cup holder/console between seats agerstein Relay General 0 05-17-2013 08:34 AM
Grocery Bag holder removal 98s10ss Vue General 11 08-13-2009 10:10 PM
Front license plate holder removal APE992 S-Series General 9 07-11-2006 01:41 PM
Removal of front licence plate holder??? Hunter Vue General 7 03-30-2005 11:04 AM
