#1 | ||||
![]() Join Date: Apr 2003
![]() I have a 1996 SL2 for my daily driver. It's leaking oil like no other. I'm just wondering where can I find this on my car. Thanks alot.
#2 | ||||
![]() It's leaking from somewhere in the back of the engine. If anyone have any more suggestions on what it could be let me know. Thanks alot.
#3 | ||||
![]() the tranaxle needs to be seperated from the engine in order to get to the rear main.
... eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe
#4 | ||||
![]() Thanks
#5 | ||||
![]() Join Date: Mar 2000
![]() If your car is a manual you need a new clutch.
Abe.
#6 | ||||
![]() At the back of the engine it could be the rear main seal or the quill (input shaft bearing seal) seal in the trans or possibly the oil pan.
... A lousy day in paradise is still a day in paradise.
#7 | |||||
![]() Join Date: May 2002
![]() 8urz06
... > 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired
#8 | ||||
![]() Yes it's a five speed, it leaks right over the exhaust and falls right onto it. I just replaced the valve cover gasket, and it still leaks.
#9 | ||||
![]() Not too familliar with Saturns, if you can't tell. lol
#10 | ||||
![]() If it is leaking onto the top of the exhaust manifold then really the only place it could be coming from would be the valve cover gasket. If it's down lower and leaking onto the exhaust pipe going under the engine then most of what I mentioned in my last post could be the source but I would lean more towards the oil pan. Get a spray bomb of engine shampoo and spray everything down and wash it off. Keep an eye on it to see if you can trace the source down.
#11 | |||||
![]() 8urz06
A Thought... ... > 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired
#12 | ||||
![]() Well, she is going to get fixed Monday. I'll let you all know what it was.
Rear Main seal | jam12 | Ion Tech | 3 | 10-20-2017 01:34 AM |
Rear main seal | kjtyo4 | S-Series Tech | 4 | 11-09-2009 05:19 PM |
Rear main seal | Saturninin | S-Series Tech | 10 | 06-19-2009 07:15 PM |
rear main seal | vtsl2 | S-Series Tech | 9 | 04-26-2008 01:51 PM |
Rear Main seal | MikeNW | S-Series Tech | 2 | 04-14-2008 11:41 PM |
