Old 02-16-2013, 09:01 PM   #1
Bentley8
Bentley8 has a spectacular aura aboutBentley8 has a spectacular aura aboutBentley8 has a spectacular aura about
Default Can a S-series hood fit in the back of a SW2?
Title of the thread pretty much states what I need to know.
I've got a dent in the hood of my '00 SW2. The junkyard has a good hood in the same color for $43. I don't know anyone with a truck.
Would this hood fit in the back of the SW2 if I angled it in there? I've tried measuring it and it seems like it will almost work, but want to be sure before I tried it.
Has anyone here done this?
And no, they won't let me swap the hoods in the parking lot, I already asked.
1999 Saturn SL2 -- 2000 Saturn SW2 -- 2001 Saturn SC1
Add to Bentley8's Reputation
Rate the quality of this post and help Bentley8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bentley8 is offline   Reply With Quote
Old 02-16-2013, 09:43 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: Can a S-series hood fit in the back of a SW2?
I doubt it. Maybe you can strap it to the top of the car, depending on the distance you have to travel.
New owner report of 08/08/19: 234,408 Miles
As of 07/25/18: 51,495 Miles
Old 02-16-2013, 09:44 PM   #3
Tie it to the roof for a 5-10min drive down the road, swap it in 10-15 minutes (30 if by yourself AND it's your first hood project), bring back the bad one
The hood may very well fit inside the hatch opening but I'd be VERY surprised if it fit between the strut tower...the space we have is taller than SL/SC's have but just as stupidly narrow.
Old 02-16-2013, 09:44 PM   #4
taatman
taatman is on a distinguished road
taatman's Avatar
Ok, so here is what you need to do! Get the hood, drive out of their parking lot to another parking lot. Then, change it out and bring your old hood back for scrap.
A hood is light, it takes two people to change it. One person holds it up while you unbolt it, then you both lift it off and voila.
Seriously, leave their parking lot and find another place a couple minutes way. There has got to be a place near by. You can also tie it down on the roof, I'm pretty sure it won't fit in the hatch.
96 SC2 - 137k - AUTO.
94 SL2 - 200k? + 2nd owner AUTO
Add to taatman's Reputation
Rate the quality of this post and help taatman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
taatman is offline   Reply With Quote
Old 02-16-2013, 11:43 PM   #5
Bring a thick packing blanket and put the new hood top side down on the blanket on the roof. Use 2 straps front and back and don't drive over 10mph. Follow previous instructions to swap. Take out the bolt closest to the front of the car on each side. Loosen each back one about 1/2 turn. Place a folded beach towel between the cowl and the center back of the hood. Lift hood and stow prop rod. Raise hood to near vertical and remove 1 bolt and then the other while holding it wit 1 hand in the center front. work both hands carefully to 1 on each side and lift up and off of car. Beware of wind.
To install set hood on the towel and get a bolt into each side, either hole first thing.
This is a 1 person job.
Do not hit or touch the lower edge of windshield. This is what the beach towel is for.
Old 02-16-2013, 11:44 PM   #6
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
IT DOES FIT
A fender fits there also with the hood
I have a pic floating around some where...... (I think on a ShawnV post....)
Just slope it a little bit......
I drove about 100 miles like that with no problems....... just SLANT IT
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
Old 02-17-2013, 12:01 AM   #7
silv01
silv01 is on a distinguished road
rent a u-haul trailer
Add to silv01's Reputation
Rate the quality of this post and help silv01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silv01 is offline   Reply With Quote
Old 02-17-2013, 06:57 PM   #8
billtag454
billtag454 is on a distinguished road
1999 SL1
I have had a hood,bumper cover and a door skin for a 2001 in the back of my 98 SW2. Just fold down the seats it will fit.
Add to billtag454's Reputation
Rate the quality of this post and help billtag454 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
billtag454 is offline   Reply With Quote
Old 02-17-2013, 10:08 PM   #9
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Ah! You do know someone with a truck, Jeff!
I was gonna hit the junkyards tomorrow. Which one is it at?
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 02-18-2013, 12:19 AM   #10
Bentley8
Shawn, you have a truck? Dang. You've got everything.
It's at the Pull-A-Part in Winston-Salem.
Old 02-18-2013, 08:44 AM   #11
ShawnV
ShawnV's Avatar
Yea man. I've got an 'o6 F250, 18' car trailer, dolly, and 5x9 utility trailer.
That's a nice yard for sure! The hood'll fit in your SW2 so you should be covered there...
shawn
Old 02-18-2013, 08:57 AM   #12
dbetz
dbetz will become famous soon enoughdbetz will become famous soon enough
1999 SW2
2000 SL
Yes, the hood will fit. I had some front-end damage that needed repair and had crumpled the front of the hood. Tossed it into the back to take it to the repair shop. Just make sure to have a blanket or something to make sure it doesn't tear up your interior.
Thanks! David
1999 SW2 Auto 150k miles; Dark Plum Metallic
2000 SL 5-Speed 214k miles; Silver
Add to dbetz's Reputation
Rate the quality of this post and help dbetz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbetz is offline   Reply With Quote
Old 02-18-2013, 09:55 AM   #13
jimboman
jimboman is on a distinguished road
jimboman's Avatar
2001 SW2
2005 ION-2 Sedan
Excellent! I had wondered whether it fits. The paint is peeling off of my old hood...
Add to jimboman's Reputation
Rate the quality of this post and help jimboman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimboman is offline   Reply With Quote
Old 03-03-2013, 12:19 PM   #14
jimboman
jimboman's Avatar
2001 SW2
2005 ION-2 Sedan
Just to remove any remaining doubt, here's a picture of my new hood in the back of the wagon. It fit with room to spare. I got it yesterday at the junkyard for $50. It looks almost brand new.
These hoods are light enough (and I suppose that I'm tall enough) that I just tied a rope to the latch loop and carried it on my back out of the yard. I think I turned a few heads.
I was also able to remove and replace it without any assistance. The ends of the hood aren't very far from contacting the vehicle of the body, so I removed the bolts with the hood prop holding it up. Don't repeat what I did if you aren't confident you can balance the whole hood as you move it over the engine compartment.
I am quite pleased. No more peeling paint!
Old 03-03-2013, 12:51 PM   #15
Curve of the hood almost looks like it was made to fit around the strut tower. Gotta love the "little SUV".
Add to madpogue's Reputation
I'm Back! My Third Blue 02 S-Series! SkippyThorson S-Series General 6 03-20-2013 12:09 AM
How-To: Opening 3rd gen S-Series hood w/ broken cable ShawnV How-To Library 0 10-16-2010 03:03 PM
Wanted: 95 SL1 or Earlier S-Series Hood Bra Steven62387 Classifieds 0 06-08-2006 09:24 PM
Back hood antennae??? BuckeyeVUE Sky General 17 02-22-2006 01:23 PM
Tell Saturn that you want the S-Series back! eric02SC2 S-Series General 42 05-06-2005 05:04 PM
