Old 07-12-2012, 10:44 AM   #1
Iturboh
Iturboh is on a distinguished road
Attention No gauge brakes applied! Helpppppp please!
Just bought a 2003 Saturn vue v6 from an auction and the car didn't start at first so I performed the reflashing sequence, however i only did one cycle and the car turned on but the gauges wouldn't work and the brakes were applied making it very hard to use, the battery was dead and we did the little sequence while having the jumper cables on, now we switched the battery with the other car and are gonna perform the whole 3 cycles, any ideas of why else it would do this?
Add to Iturboh's Reputation
Rate the quality of this post and help Iturboh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Iturboh is offline   Reply With Quote
Old 07-12-2012, 11:02 AM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: No gauge brakes applied! Helpppppp please!
The brakes were applied... meaning you were applying the brakes, or they're froze up in the applied position?
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 07-12-2012, 11:51 AM   #3
far2grumpy
far2grumpy's Avatar
In theory you'd only need to complete Passlock relearn (I'm guessing thats what you mean) if SECURITY light is flashing with key turned on.
Check the IPC (instrument panel cluster) fuses in center console fuse block. Access cover is next to seated front passenger left foot.
The gages - and all other lights except SECURITY light - are controlled by class 2 data lines. If IPC fuses are OK it could be bad ECM, BCM, interconnecting wiring.
You probably should check all fuses with an ohm-meter.
Can you jack Vue up to find if just one or all wheels are hard to turn?
Knocks from rear brakes when applied hydromech S-Series Tech 2 07-09-2011 05:31 PM
Hard brakes, Climb in rpm when brakes applied motodan S-Series Tech 7 05-17-2010 10:22 PM
Click in Shifter when Brakes Applied danf L-Series General 4 12-22-2005 04:44 PM
96 sw2 stalls when brakes applied jmorrell S-Series General 2 05-31-2005 03:38 PM
Sudden Power Off When Brakes Applied SallySueSo S-Series General 13 05-07-2005 12:30 AM
