Old 10-13-2011, 08:40 PM   #1
al_ls2
al_ls2 is on a distinguished road
Default 2000 saturn ls2 turn signal
hello everyone i bought a 2000 saturn L- series and im having problems with the turn signal/milti-function switch ...when i bought the car the turning signal switch wouldnt return automatically so i bought a new one but im still having the same problem ...any ideas what would the problem be?
Add to al_ls2's Reputation
Rate the quality of this post and help al_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
al_ls2 is offline   Reply With Quote
Old 12-26-2011, 11:29 PM   #2
dino3721
dino3721 is on a distinguished road
Default Re: 2000 saturn ls2 turn signal
I had the a similar issue. Are you sure the switch is seated in both sets of clips? Mine was not seated all the way- and now works just fine.
Add to dino3721's Reputation
Rate the quality of this post and help dino3721 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dino3721 is offline   Reply With Quote
Old 01-03-2012, 12:52 PM   #3
HV Fam Wagon
HV Fam Wagon is on a distinguished road
2000 L-Series 3.0L Wagon
2004 L-Series 3.0L Wagon
I have the same problem. I replaced the switch assembly, and it still won't cancel the signal after turning. The wagon passed inspection; I might just live with the problem.
Add to HV Fam Wagon's Reputation
Rate the quality of this post and help HV Fam Wagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HV Fam Wagon is offline   Reply With Quote
Old 01-03-2012, 09:46 PM   #4
Pull the signal switch out and have a look into the hole to the center of the steering column to see if you can see the cancelling tab, you may have to turn the steering wheel. It is part of the SIR clockspring coil I have seen them break off.
Add to ssicarman's Reputation
1995 Saturn SL2, procedure to replace combination turn signal / wiper switch David598 S-Series General 8 01-08-2010 08:46 PM
Turn Signal richamer1 Ion General 5 08-11-2008 10:48 AM
Turn Signal Bogel S-Series Tech 6 04-08-2008 08:27 PM
Turn Signal Problem on 2000 LS1 Kenk L-Series Tech 7 03-12-2008 03:34 PM
99 SC turn signal sat96 S-Series General 2 01-31-2005 01:13 PM
