Old 10-21-2010, 04:12 PM   #1
Silversand
Silversand is on a distinguished road
Default wrong oil filter
Just got my oil changed and noticed on my invoice that the dealer used GM part # 9192426 for the oil filter. I have a couple of spare filters at home and know that the correct part # is 93185674.
A little searching reveals that the filter they fitted is a tiny bit wider internally and overall about 20mm shorter in height.
Anyone know if I can get away with keeping this filter on without oil flow problems??
09 Astra XE 5dr, Silver Sand, M5
08 Escape XLT V6 FWD, Tungsten Grey, A4
Add to Silversand's Reputation
Rate the quality of this post and help Silversand reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silversand is offline   Reply With Quote
Old 10-21-2010, 06:57 PM   #2
99blacktop
99blacktop is on a distinguished road
99blacktop's Avatar
Default Re: wrong oil filter
I would take it back and tell them to use the correct filter and if they say that they did, but the invoice is wrong, I'd make them prove it. 20mm is pretty significant on such a small filter.
My Saturn history:
1993 SL2 100,406 miles ('94-'98)
1999 SC2 118,537 miles ('98-'12)
2005 VUE 25,705 miles ('05-'09)
2008 Astra 27,014 miles ('09-'12)
Add to 99blacktop's Reputation
Rate the quality of this post and help 99blacktop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99blacktop is offline   Reply With Quote
Old 10-22-2010, 09:47 AM   #3
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Probably a simple "part number change-up". Happens all the time in both the OEM and aftermarket worlds when they realize that either a) they already have an 99% identical filter under a different number, or b) they've modified the factory filter somehow and have to sell v2.0 under a different part number. The original part number will likely continue to be sold until the stock is completely diminished, at which point you will have no choice in the matter. The person behind the parts counter will most likely tell you that the number changes up, which means that the new # "officially" replaces the old one and you've got nothing to worry about.
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
Old 10-24-2010, 10:19 AM   #4
Silversand
Turns out the filter part # installed is the correct filter for a number of other GM of Europe products - 3.0 V6 in the Catera, CTS, Saturn L300. Also would work on a previous generation Astra (Astra G 1998-2003) with a 1.8 litre.
Called dealership about it, they said to bring it back for them to install the correct filter...
Old 10-24-2010, 06:04 PM   #5
Nightwalker
Nightwalker is on a distinguished road
Nightwalker's Avatar
2008 Astra XR
2005 ION-2 Sedan
See, its stuff like this that makes me do my own work. I HATE taking my car to the dealership unless I 100% have to. I just don't understand how they can be so sloppy or make such an error. Its not like this is joe-bob's value lube shop, these are official shops.
I had a 94 SL2 that had the odometer stop on it. By law, I can't touch it.
I took it in to get fixed, and not only did it cost $700+ to replace, but it was with a USED cluster unit. The first unit they installed was also defective. After they ordered and installed the second one, they didn't even tighten the wires correctly, so it would cut in and out.
It just burns me up that they can do this crap. GM sent me a card good for 4 free oil changes on my Astra, but I don't plan on using it.
My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456
2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
Add to Nightwalker's Reputation
Rate the quality of this post and help Nightwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nightwalker is offline   Reply With Quote
cabin filter and inline transmission filter? mrtube Vue Tech 10 12-04-2009 08:38 PM
Oil change/filter & trans fluid /filter job completed ken b. S-Series General 2 06-03-2006 01:17 PM
Saturn messed up idles wrong, sounds wrong Pandoraisgod S-Series General 7 01-24-2005 03:25 AM
Wrong Oil Filter!!! flappytango Vue General 7 02-16-2004 08:52 PM
