Old 07-15-2010, 09:28 PM   #1
J302
J302 is on a distinguished road
Default 99 SL miss at idle only
1999 SL with the SOHC engine. Recently I noticed a miss at idle, and hoping someone can point me in the right direction. Here are a few details:
- 185000 miles, 5 speed, new plugs, wires
- Bought two new coils and ignition module, replaced it all, still no difference
- Checked fuel pressure at idle, rock solid at 50 psi
- No check engine light
- sprayed carb cleaner around the intake manifold for leaks, didn't make a difference
- tried switching plugs, nothing
- tried switching wires, nothing
- unplugged one sparkplug wire at a time, the miss didn't seem to be affected (I could hear a miss caused by the unplugged wire, but no additional miss down to two cylinders)
The idle is good, them you can hear the miss on a cylinder, then good, then the miss, its almost rhythmic. It seems to go away when the gas is applied. I don't notice anything abnormal while driving.
I figure the intake manifold gasket maybe the problem, but before I attack it, I would like to hear a few opinions. My 2001 had the intake manifold gasket go, but it also set a CEL. This one is not setting one. Also, reading other posts, it seems the EGR valve could be a problem, but I figured that would set a code and the CEL would come on.
Thanks for any advice, I love this car, has been super reliable, but this problem has me stumped.
Add to J302's Reputation
Rate the quality of this post and help J302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J302 is offline   Reply With Quote
Old 07-15-2010, 10:33 PM   #2
bluesl2
bluesl2's Avatar
Default Re: 99 SL miss at idle only
Double check the intake gasket, if that is ok maybe it's a partially plugged injector. Try checking compression as well, could be a sticky valve.
Add to bluesl2's Reputation
Old 07-16-2010, 03:26 PM   #3
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Also look at the plug routing There is a little black Square on the fender with the emmissions info and it will show you the wiring layout. I.E. 4,3,1,2.
Old 07-16-2010, 05:07 PM   #4
J302
Thanks for the inputs, I picked up an intake manifold gasket, and will try to work on it this weekend. The cable routing and firing order are as they should be.
Old 07-20-2010, 11:54 PM   #5
sbr65nj
sbr65nj is on a distinguished road
sbr65nj's Avatar
2000 SL2
Dizzy Re: 99 SL miss at idle only
Having the exact exact same issue with my 2000 sl2. Please let me (us) know how the intake manifold gasket replacement went and if that does indeed solve this issue. On my car is sounds like a "put put"
Add to sbr65nj's Reputation
Rate the quality of this post and help sbr65nj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sbr65nj is offline   Reply With Quote
Old 07-21-2010, 07:16 AM   #6
J302
To sbr65nj: Are you getting a check engine light? 2000-2002 are known for intake manifold gasket problems (as I stated, I had a 2001 with the problem, and replacing the gasket fixed it). My 2001 set a P0301 (Cylinder #1 misfire detected) code. The older ones like my 1999 are not known for the problem, but it could be the gasket.
BTW, I cleaned my EGR valve which was extremely clean for having 185K miles on it, new gasket, absolutely no difference in idle. I also ordered a single fuel injector, that should be here this weekend. I'll update this thread as soon as I find out something.
Old 07-21-2010, 12:22 PM   #7
topcat
topcat will become famous soon enough
topcat's Avatar
Note: the correct firing order is 4-1-2-3.
Add to topcat's Reputation
Rate the quality of this post and help topcat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
topcat is offline   Reply With Quote
Old 07-21-2010, 12:32 PM   #8
Originally Posted by topcat View Post
Note: the correct Wiring order is 4-1-2-3.
Fixed (firing order is 1-3-4-2).
Add to madpogue's Reputation
Old 07-21-2010, 05:23 PM   #9
adventureoflink
adventureoflink's Avatar
....huh?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 07-21-2010, 06:37 PM   #10
Originally Posted by adventureoflink View Post
....huh?
Um, well, uh, first #1 fires (that is, actually ignites compressed fuel). Then #3 fires. Then #4 fires. Then #2 fires.
(Then #1 fires again.)
Old 07-23-2010, 02:55 PM   #11
J302
Did a static compression test on the motor this morning, got 125-155-155-155. I take #4 (passenger side when looking from the front of the vehicle) is the culprit, its also the one I have suspected of giving me a lifter tapping noise recently.
I think at this point, it is not cost effective to tear the motor down, I have a lower mileage 50K motor from a 2001 SL1, which will likely find a new home in an old engine bay. I realize some of the year differences, but swapping some sensors and the throttle body, things should line up.
I appreciate everybody's inputs and help, I will post any problems I find with the engine swap as soon as I find the time to start it. Thanks.
Old 07-24-2010, 05:56 PM   #12
J302
I guess my couriosity got the best of me. I replaced the intake manifold gasket, and the car runs much better than before. Once I put it back together, the idle smoothed out, no more rythmic miss, but I still get an occasional miss. The old gasket was very brittle, looks like it was damaged at the #4 intake (I am surprised that the brake cleaner test didn't affect it). The intake runners and port are full of carbon deposits, I guess 186K miles does that. I am considering running seafoam thru it, but the neighborhood association might have a problem with the smoke show.
Old 08-13-2010, 12:43 PM   #13
sbr65nj
sbr65nj's Avatar
2000 SL2
Re my 2000 SL2
I replaced the intake manifold gasket on mine as well. It had been replaced as a SUPPOSED warranty repair in/around 2003. Well it seems that the dealership left a few remnants of the old gasket there (that the dealership that did the previous repair kindly left for me). Car drives like new. It still misses on occasion but it runs with at least 20-30% more power. So ends the saga...
New 07 XR owner- Miss at idle ?????? PULLNIT Aura General 17 09-03-2010 02:30 PM
Slight miss in rhythm of idle 10W30 S-Series Tech 15 12-26-2006 07:56 PM
L200 Engine miss at idle MerrittK54 L-Series General 8 04-04-2006 11:29 PM
99 SL High Idle, Miss Cylinder #1, Vacuum mcfly S-Series General 6 11-26-2005 01:54 PM
Slight miss at idle white95SL1 S-Series General 1 10-13-2004 10:33 PM
