Old 11-13-2019, 12:13 AM   #21
GOODY2SHZ
GOODY2SHZ is a jewel in the roughGOODY2SHZ is a jewel in the roughGOODY2SHZ is a jewel in the rough
1997 SL
2002 SL
Default Re: P0410 error code - HELP
So we pulled off the exhaust manifold and cleaned it out but it wasn't very dirty and there were no obstructions. Cleared the code and then drove the car. The SES light came back on after around 40 miles. We've already done the full diagnostic from the Richpin video and everything seemed to be working properly. But there are a few things I'm not sure about.
First, with all the normal noise and vibration from the engine, I couldn't really be sure whether or not the smog pump was actually coming on. If I do a cold start then immediately go out and put my hand on the pump, should I be able to feel a definite change when it shuts off in about 30 seconds? How can I know for sure it's coming on? There's power at the switch to the pump and at the switch to the diverter, and there's a vacuum at both hoses attached to the diverter.
The other thing I am unsure about is the diverter. When we disconnected the silver tube from it, there was air coming out of the diverter but it wasn't very strong. The pump may have already turned off at that point, not sure if that made a difference. Or maybe that's just the way it's supposed to be.....
Anyway, any help figuring out what we should do next would be greatly appreciated.
Add to GOODY2SHZ's Reputation
Rate the quality of this post and help GOODY2SHZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GOODY2SHZ is offline   Reply With Quote
Old 11-13-2019, 09:36 AM   #22
BV22
2002 SC1
Remove the silver tube and do a cold start. Air flow out of the open end of the diverter valve should be strong. If it is not, either the air pump is weak or not running or the diverter valve is not opening.
When you had the exhaust manifold off, did you clean out the 4 air ports that go through the cylinder head? These holes clog more often that the manifold passage itself.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 11-13-2019, 02:33 PM   #23
GOODY2SHZ
1997 SL
2002 SL
Thanks for your help!
I removed the two 10mm bolts holding the silver tube onto the diverter and did a cold start. There was a good amount of air coming out of the silver tube where it would have been connected to the diverter but there was hardly any air coming out of the hole in the diverter. I kept my hand on the pump but couldn't tell whether it was on or not. Unless there's a way I can figure out if the pump is actually coming on or not, I'm thinking I should order a new diverter. What do you think?
Old 11-13-2019, 03:25 PM   #24
BV22
2002 SC1
Next step is to disconnect the big black hose that goes from the air pump to the diverter valve at the valve. Do another cold start and check for air flow coming out of the hose. If there is flow, the pump is working and the diverter valve is likely shot. If no flow, then the air pump is not running.
I presume from your description of the most recent test that you had exhaust coming out of the silver tube, but no air coming out of the diverter. Correct?
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 11-13-2019, 04:46 PM   #25
GOODY2SHZ
1997 SL
2002 SL
Yes, that is correct. I will do the big black hose test tomorrow morning on a cold start and post my results. Thank you!
Old 11-14-2019, 03:02 PM   #26
GOODY2SHZ
1997 SL
2002 SL
I disconnected the big black hose coming from the pump to the diverter at the diverter and there was good air flow. There was also a slight squeal that I could only hear when the hose was disconnected.
So, I'm assuming now we've completely isolated the problem to the diverter. Do you concur?
Old 11-18-2019, 09:18 AM   #27
BV22
2002 SC1
If you have previously verified that you have vacuum at the diverter valve while the air pump is running, then yes, the diverter valve is not opening and must be replaced.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 11-26-2019, 09:49 PM   #28
GOODY2SHZ
1997 SL
2002 SL
Finally received the diverter from Rock Auto and installed it. Did a cold start and there was a good flow of air coming out the hole where the diverter connects to the silver tube. Put everything back together and took it on a very long drive. After just over 200 miles the service engine soon light went out. Yippeeee! Now to get it smogged. Thanks BV and everyone else for your help!
Old 11-27-2019, 09:28 AM   #29
BV22
2002 SC1
Glad you got it sorted. It is a nice feeling of accomplishment when that SES light goes off after a repair.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Check Engine error code P0410 Bleach S-Series Tech 6 06-05-2016 06:06 PM
P0410 Error Code pgp_protector S-Series Tech 5 08-18-2009 12:12 PM
P0410 Error and Frustration: psmaglik1965 S-Series Tech 4 03-26-2008 08:50 AM
p0410 code storm_amoure S-Series General 3 11-10-2007 04:12 PM
Code P0410 Yellow Hornet S-Series Tech 2 01-25-2005 11:25 PM
