Old 05-13-2009, 06:14 PM   #1
jonny772
jonny772 is on a distinguished road
2005 ION-2 Sedan
2003 ION-1 Sedan
Default ignition switch
So the dealership wants to charge 300 dollars and then some to replace the ignition switch in my wifes 03 ion 1. I took a look at where it goes and what it takes to replace and its pretty simple or so I thought at least untill o talked to the parts guy. He said the reason that the install was so expensive was that they had to reprogram the switch due to the passlock system. I read online and in my haynes that all reprogramming entails is turning the car on and off in ten minutes cycles.who is right? Thanks for your help.
Add to jonny772's Reputation
Rate the quality of this post and help jonny772 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jonny772 is offline   Reply With Quote
Old 05-13-2009, 06:28 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: ignition switch
the manual is, but you can degrease your old one and re grease it with an appropriate dielectric grease for the cost of the grease and not have to reprogram it.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 05-13-2009, 06:37 PM   #3
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
So what you are saying is either way I need to remove the ignition switch. But if I want to replace it all it takes is the 10min on off procedure? Thanks again. And what kind of grease?
Old 05-13-2009, 08:30 PM   #4
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
let me add a question about the reprogram procedure, when it says to put the key in the run position does that mean try to start it for 10 minutes?
Old 05-14-2009, 12:15 PM   #5
desired name
desired name is on a distinguished road
desired name's Avatar
2003 ION-3 Sedan
No there isn't a battery that could stnd that . Just turn it to the run position with the engin off. Do not turn it to start.
But you wont have to reprogram anything if you just open the plastic switch and wipe off the old dirty grease. I did mine this christmass and havent had a problen since.
Add to desired name's Reputation
Rate the quality of this post and help desired name reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
desired name is offline   Reply With Quote
Old 05-14-2009, 01:11 PM   #6
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
Default
Sorry post was answered
Old 05-14-2009, 01:52 PM   #7
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
Is it fairly straightforward as how to take the switch apart and clean/replace grease once I get the switch out? Thanks.
Old 05-15-2009, 07:24 PM   #8
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
So I just now took the switch apart. Cleaned the old grease off. Applied a very thin coating of new grease and reassembled and reinstalled the switch. The car started fine twice but now has the service car alert on the dash. I would think that this means that I do need a new switch. Thanks
Old 05-16-2009, 12:00 PM   #9
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
So today I put in a new switch. Go thru the reprogramming procedure. Then when I try to start the car it half starts then says service vehicle. I am at a loss for what's going on. I did the procedure twice just in case and same result both times. Any ideas. Thanks
Old 05-16-2009, 01:59 PM   #10
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
Well one last add since I think its fixed maybe. Just went out to the car and it started up just fine about 5 different times. So like I said if anyone has any ideas let me know.
Old 05-16-2009, 02:23 PM   #11
2006 ion2
2007 ION-2 Sedan
you wasted your money on the new switch, your car needs to clear the code before the message goes away.
2007 Saturn Ion 2
Old 05-16-2009, 02:31 PM   #12
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
Well I guess that's a lesson learned. Thanks for the help anyway
Old 05-16-2009, 03:06 PM   #13
2006 ion2
2007 ION-2 Sedan
you're welcome, I actually have two code scanning/clearing devices that also have other functions to make sure problems are real and confirm repairs.
2007 Saturn Ion 2
Old 05-16-2009, 03:14 PM   #14
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
I suppose I have to look at the fact that I only spent 35 dollars to find out all I needed was to spend nothing. Instead of the 300 the dealer wanted. Thanks again
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
Ignition Switch- PLEASE HELP DarrylLeeOHS30 S-Series General 0 10-08-2005 08:57 PM
ignition switch staroffear S-Series General 7 05-14-2005 10:40 AM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
Ignition switch ? Russ Bellinis Miscellaneous Tech 4 08-26-2002 03:02 AM
