Old 10-02-2008, 12:23 PM   #1
GmG
GmG is on a distinguished road
GmG's Avatar
1992 SC
Default 98 SC2 running poorly, dumping gas
I had my 98 SC2 sit at my mechanic's shop for a couple months while I tried to find a used header downpipe. After it sat, it was running really poorly, barely running at all. We replaced the coil packs, cleaning the mounting surface well and applying dielectric grease. Now the car will idle fairly well, but is still dumping way too much gas. We've tried different wires and plugs, and after running for a couple minutes, two of the plugs come out soaked with gas, two come out black. We're doing a compression test later, but are kind of at a loss for what to do next. Thanks in advance for any suggestions.
George
92 SCm 138k
98 SC2m 131k
"You shouldn't leave things in the fridge. That is the lesson."
Add to GmG's Reputation
Rate the quality of this post and help GmG reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GmG is offline   Reply With Quote
Old 10-02-2008, 02:15 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: 98 SC2 running poorly, dumping gas
Pre-2001 fuel/air problem first thing to try is the ECTS.
Use the forum jump at the bottom of the page and go to the How-To Library. Near the top of the forum, you'll find instructions for replacing it.
Add to BarnOwl's Reputation
Old 10-02-2008, 02:32 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
You're gonna be kicking yourself when you find out a $14 part was most likely the cause of your problems.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 10-02-2008, 04:31 PM   #4
GmG
GmG's Avatar
1992 SC
I should have posted that we double checked the ECTS to be sure we had replaced it, and it was replaced with a new brass tipped one from saturn, as well as the connector/wires. I forgot to post that it is throwing one of the cam sensor codes, so we went through the procedure on the board and ruled out the ignition module.
George
92 SCm 138k
98 SC2m 131k
Old 10-02-2008, 04:35 PM   #5
BarnOwl
BarnOwl's Avatar
The cam sensor codes (P0340 and P0341) indicate and ignition problem. How are the plugs and wires?
Old 10-02-2008, 09:23 PM   #6
GmG
GmG's Avatar
1992 SC
I can't find the thread right now, but it went over how to diagnose the "cam sensor" codes. We went through that, the wires tested with proper resistance, but we tried different ones anyway, to no success. We've tried new plugs. Compression is good (180-200). I mentioned to the mechanic that he may want to get a real-time readout of the coolant temp on his scanner to make sure the ECTS is working right, so he's going to do that tomorrow...
George
92 SCm 138k
98 SC2m 131k
Old 10-02-2008, 09:38 PM   #7
The cam position errors are from the flooded engine when you found all the plugs soaked/blackened from too rich a mixture. When you pulled the plugs did anyone blow out the cylinders by blipping the starter to blow out any remaining gasoline? This would have allowed another clean re-start unless the wet plugs were just put back in instead of drying/cleaning them of deposits.
There are several places where a rich fuel mixture would flood and engine; excessive fuel pressure, leaking injectors, disconnected ects, corroded ects connector, another faulty ects, blown fuel pressure regulator diaphragm where vacuum pulls fresh fuel into the vacuum line into the intake manifold.
Old 10-04-2008, 09:45 AM   #8
GmG
GmG's Avatar
1992 SC
That's a good point, I'll ask him about blowing out the remaining fuel before putting the plugs back in. He asked me about the fuel pressure regulator, and I remembered we had replaced the fuel filter on schedule at around 100k, so it has about 2 years/30k on it now, to take a guess. I believe I bought the filter directly from Saturn. At what point would you view a faulty regulator as the culprit? When he gets to the shop this morning, I'm going to see if he got a readout on the ECTS yet, just to confirm its proper function.
George
92 SCm 138k
98 SC2m 131k
Old 10-04-2008, 09:55 AM   #9
I would check your key on engine off fuel pressure. Then I would monitor pressure decay. Max pressure is 51 psi and the acceptable range when running is 45-51psi. After pressurizing the system the pressure should hold above 45 psi key off for at least 5 min. That is an average spec not the minimum. The min spec is less than 8 psi drop in 5 min.
Old 10-04-2008, 12:51 PM   #10
After checking fuel pressure, that automatically informs you of pressure and any leakdown immediately after just turning ON the ignition without running the engine. This takes care of injector and regulator leaks. One outside possibility of the rich mixture may be from a plugged exhaust system - the cat con rotting away to block exhaust flow while starting the engine after letting it sit for a few months. If engine running is still erratic, try removing the front O2 sensor and see if the engine runs better. The extra hole allowing better exhaust flow may help indicate a blocked catcon.
Old 10-05-2008, 12:02 AM   #11
GmG
GmG's Avatar
1992 SC
Thanks again for the good advice, that's what we'll pursue Monday and I'll report back when we know something.
George
92 SCm 138k
98 SC2m 131k
Old 12-06-2008, 07:14 PM   #12
GmG
GmG's Avatar
1992 SC
I wanted to post a follow-up to my issues. We eventually ran out of things to test, so we decided to throw a used PCM at it, since it was only $50, which didn't work, then tried an ignition module, which did the trick. I don't know if we did something wrong when testing it in the first place, but she's running great again! So thanks again to those who helped out, and Merry Christmas to all!
George
92 SCm 138k
98 SC2m 131k
Poorly running engine. please help drs24 S-Series Tech 3 09-03-2009 11:27 PM
SW1 still running poorly :( striider S-Series Tech 6 03-27-2006 05:22 PM
Running poorly? Another "possible" answer. JerryHughes S-Series General 0 09-26-2005 03:43 PM
car performs poorly unless gas tank is full mkosem S-Series Tech 20 04-16-2003 08:29 PM
Strange Diagnosis of Poorly-Running Single Cam... 93BLKTWINCAM S-Series Tech 2 07-29-2002 08:42 PM
