Old 11-16-2007, 01:09 AM   #1
madeinUSA
madeinUSA is on a distinguished road
madeinUSA's Avatar
1992 SL2
1998 SW2
Default Diff-Pin Mod
The roll pin for my diff pin broke & cracked the trans case (manual) on my '92 SL2. I have another trans but will not put it in until I can secure the diff pin better (seen this happen too many times). What do you guys put in place of the roll pin? (I did a search in Mods forum& could not find anything; Sorry if this has been coverd before or I am in the wrong place..Thanks!)
'92 SL2 / '91 SC / '06 Cobalt SS (supercharged!)....Proud American driving American made!
madeinUSA is offline   Reply With Quote
Old 11-16-2007, 01:38 AM   #2
dragon370
dragon370 is on a distinguished road
dragon370's Avatar
Default Re: Diff-Pin Mod
you weld the stock pin in place.
Brendan
1997 SC1- "Stacy" dk green, 5spd, Motegi, Kuhmo tires
Under the most rigorously controlled conditions, the Saturn will do as it damn well pleases.
dragon370 is offline   Reply With Quote
Old 11-16-2007, 02:13 AM   #3
GmG
GmG is on a distinguished road
GmG's Avatar
1992 SC
Picture from wolfman: http://www.saturnfans.com/photos/sho...00/ppuser/3528
I know there's others in the gallery. Searching for something like "weld diff pin" should give you a bunch of old threads.
George
92 SCm 138k
98 SC2m 131k
"You shouldn't leave things in the fridge. That is the lesson."
GmG is offline   Reply With Quote
Old 11-17-2007, 09:02 AM   #4
94503
94503 is on a distinguished road
u dont need a whole new tran u can replace the diff and the bell housing from another tran also
94503 is offline   Reply With Quote
Old 11-17-2007, 12:57 PM   #5
S3aturnR
S3aturnR's Avatar
1999 SL1
i would think that if the diff pin was welded, you could then remove the roll pin altogether. i've never done that, tho...
s3aturnr
Old 11-17-2007, 03:32 PM   #6
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
no sense in removing the roll pin...
weld it!!
and your spider gears can still come flying out of your trans...
P.S. quit spinning the tires!!!
BlackBirdRacing is offline   Reply With Quote
Old 11-18-2007, 11:11 PM   #7
madeinUSA
madeinUSA's Avatar
1992 SL2
1998 SW2
Thanks for the info...does welding the pin have any side effects? Mine broke while backing up...stopped the car like I hit a stump! I guess almost 200,000 miles finally broke the original roll pin. Again thanks for the help....this site is much more mature than over on Cobaltss.net!
Old 11-19-2007, 05:22 PM   #8
tarsun
tarsun is on a distinguished road
i just used a paper-clip. seems to work well
tarsun is offline   Reply With Quote
Old 11-19-2007, 05:42 PM   #9
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
Is this just a Manual tranny thing or could this happen to an auto....im pretty easy on mine....
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
xtremeranger is offline   Reply With Quote
Old 11-19-2007, 09:29 PM   #10
wolfman
wolfman's Avatar
Same open differential is use in both the automatic and manual "S" series transaxles...
Old 11-26-2007, 04:40 AM   #11
xtremeranger
2005 VUE Red Line
2006 ION Red Line
Damn......Im really easy on mine but if the front tires lock up doing 70 on the highway...I guess ill have an idea of what happened.....
Old 11-27-2007, 07:43 PM   #12
myoung
myoung is on a distinguished road
myoung's Avatar
you have to do a better job than in that picture if you expect it to hold up. once I blew one welded one up, I wised up. taper the edges of the diff pin and grind some away around the edges so that you have a large groove to lay a bead of weld in. I did that the second time around and it's still ticking (albeit with a different driver, I've moved on to nicer cars)
myoung is offline   Reply With Quote
Old 12-01-2007, 12:08 AM   #13
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
I may be off here but doesn't the diff pin spin as long as the car is moving and at the speed it is moving at? If so I don't see how doing burn-outs would make the pin any more susceptible to flying apart than driving down the freeway at 75mph.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Cat Fuzz is offline   Reply With Quote
Old 12-01-2007, 08:26 AM   #14
Because going down the road at 70, there isn't a major difference in tire speed from each other. It's not the spinning of the tires that blows the pin it's when one hooks up before the other one.
Old 12-05-2007, 11:28 AM   #15
BarnOwl
BarnOwl's Avatar
If you really want a permanent fix and money's no object, you could always go with a Quaife.
Old 12-05-2007, 11:53 AM   #16
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Same deal with locking your tires at 70 as one of the above posters mentioned. If one tire locks, and the other one spins yet, your diff will really take a beating.
If it ain't broke it's over designed.
Diff Pin... mk43 S-Series Tech 3 11-01-2007 06:57 AM
Differential Pin (DIFF PIN) Inspection richpin06 S-Series Tech 4 03-21-2007 11:30 PM
Diff Pin 99/02SC2Kid S-Series Tech 19 06-29-2006 11:35 PM
diff pin kidkilla420b S-Series Tech 4 01-20-2004 10:25 PM
PG Diff Pin Tycho Mods and Performance 1 07-07-2002 11:24 AM
