Closed Thread
Old 12-15-2004, 11:11 AM   #1
pruitts
pruitts is on a distinguished road
Default What size of LED for automatic window/cruise control?
My husband wants to replace the LEDs on the automatic window control and the cruise control in his Vue, from orange to blue. If anyone has any information on what the size of the LED is (and any other pertinent information I need), I would gladly appreciate it. I want to try to get him these as a Christmas present...
Thank you.
Add to pruitts's Reputation
Rate the quality of this post and help pruitts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pruitts is offline
Old 12-15-2004, 12:53 PM   #2
VUEnumber1
VUEnumber1 will become famous soon enough
VUEnumber1's Avatar
2007 VUE 3.5L
2005 VUE 3.5L
Default Re: What size of LED for automatic window/cruise control?
They're 3mm LEDs. That's what I used.
I'd avoid using the "super bright" variety, as they'll light up your headliner and he'll have to take it all apart again and put a filter of some sort over the LED. Ask me how I know that.
Add to VUEnumber1's Reputation
Rate the quality of this post and help VUEnumber1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEnumber1 is offline
Old 12-15-2004, 02:38 PM   #3
robert_vue
robert_vue is on a distinguished road
robert_vue's Avatar
2005 VUE 2.2L
I agree on not using the super bright ones. Occasionally when sitting and talking with a passenger in the front seat we have to put napkins or a jacket over the center console. As the driver, you get used to them -- I had a bright blue one on the cruise control light too, but your passengers can't always get used to them.
When doing the driver's window, be very careful -- my automatic down stopped working on it after I soldered on the LED.
Robert R.
03 VUE: Oct 15, 2002 - Dec 5, 2004 R.I.P.
Add to robert_vue's Reputation
Rate the quality of this post and help robert_vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robert_vue is offline
Old 12-15-2004, 04:31 PM   #4
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
So, you just have to heat up the legs on the old LED and pull it off, then solder the new one on? Is it really that simple, or is there a trick here? My confidence with soldering and LEDs is growing as I do other little projects, and this one (like SQVue's sweeet setup) is one I'd like to get done by next summer. TIA.
Tupperware cars FTW!!!
Add to Dante's Reputation
Rate the quality of this post and help Dante reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dante is offline
Old 12-15-2004, 05:09 PM   #5
robert_vue
robert_vue's Avatar
2005 VUE 2.2L
I suck at desoldering (I think I need that bulb to suck off the solder), so in the end I just ended up cutting off the LED and soldering the new one on at the board. This worked best for me.
Robert R.
Old 12-15-2004, 06:22 PM   #6
pruitts
Any idea what store or internet site I purchase these from?
pruitts is offline
Old 12-15-2004, 08:05 PM   #7
VUEnumber1
VUEnumber1's Avatar
2007 VUE 3.5L
2005 VUE 3.5L
I just pulled the old one off with the iron melting the solder, then pushed a new one in, also with the solder melted. You could also just cut the old one off like robert did and solder the new one to the legs left behind.
You just have to bend the wires the right way on the driver side to get automatic down switch to work.
Old 01-11-2005, 12:33 AM   #8
robert_vue
robert_vue's Avatar
2005 VUE 2.2L
I cannot for the life of me remember how to take apart the window controls on the left hand side. I'm actually stuck on removing the rear window child lock control thing. I cannot remember how that thing pops up. I've finished the right hand window side (bright blue), but now need to work on the left hand side.
Arghhh!
Thanks.
Robert R.
Old 01-11-2005, 12:55 AM   #9
VUEnumber1
VUEnumber1's Avatar
2007 VUE 3.5L
2005 VUE 3.5L
The rocker pulls straight up. Make sure it's not tilted to one side (locked or unlocked) and pull it straight up.
John
Old 01-11-2005, 01:13 PM   #10
robert_vue
robert_vue's Avatar
2005 VUE 2.2L
And then, I finally figured it out. It has to come off somehow I figured, and I yanked it off from the side (the direction the rocker goes). I was trying from the other side (perpendicular to the rocker direction) and the plastic just ends up bending like it's going to break. SCARY!
So off topic, those of you that solder onto the PCB, what equipment do you use? I've determined that almost for sure, I am using the WRONG equipment. Also what kind of solder do you use? I think my solder is wrong too. My solder works perfect for joining two wires together, but sucks when it comes to the board.
Anyways, my cruise control LED, and window LEDs are finally complete, and this time I didn't mess up the Auto-Down feature on the driver's side door.
Robert R.
Old 01-11-2005, 05:20 PM   #11
evilburl
evilburl is on a distinguished road
evilburl's Avatar
2004 VUE 2.2L
1993 SL2
Thank you.
OMG my wife thought I was crazy to want to do this,,, cool
[COLOR=DarkRed]My SL2 has over 300 000 kl on it and still keeps going and going. [/COLOR]
[COLOR=Blue]My VUE is on its way :)[/COLOR]
Add to evilburl's Reputation
Rate the quality of this post and help evilburl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
evilburl is offline
Old 05-23-2005, 03:21 PM   #12
evilburl
evilburl's Avatar
2004 VUE 2.2L
1993 SL2
I found the adpmods web store has them. the linky ishere.
evilburl is offline
Old 05-25-2005, 09:57 PM   #13
beachkeefes
beachkeefes is on a distinguished road
beachkeefes's Avatar
2004 VUE 2.2L
Any Radio Shack store (or radioshack.com) should have them.
Add to beachkeefes's Reputation
Rate the quality of this post and help beachkeefes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beachkeefes is offline
Old 07-13-2005, 04:46 PM   #14
TheDude
TheDude is on a distinguished road
Happy Re: What size of LED for automatic window/cruise control?
Are the switches pretty easy to remove? Does anyone have any procedures (with pics) on how to do this?.
Add to TheDude's Reputation
Rate the quality of this post and help TheDude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheDude is offline
Closed Thread
Cruise Control Not so good on the control part? aph3x Outlook General 2 10-15-2007 08:39 PM
I've lost control of my cruise control stainlesswelder S-Series General 10 10-21-2006 12:18 AM
LED size in instrument cluster? jrworkman1 Ion General 16 11-07-2005 01:48 PM
Window Switch LED Swap burnout Vue General 3 08-29-2005 09:29 AM
manual cruise control for an automatic choc citysaturn Mods and Performance 2 12-15-2004 01:44 AM
