#1 | ||||
![]() ![]() ![]() ![]() ![]() Join Date: Aug 2011
2003 ION-3 Sedan
![]() Hi all,
I have two of the center brake light bulbs burned out on my '03 Ion. The owners manual says they are a PC-175 bulb, but none of the auto parts stores around me seem to carry that bulb type. My question is: is the yellow socket that twists into the brake light assembly supposed to be replaced with the bulb? I initially tried replacing just the bulb itself with the closest bulb the store carried - a Sylvania 194. The bulbs themselves have the same base, but the metal contacts are slightly different, and I only got one of the two to work. I've had the car for almost a decade, and this is the first time I've ever had to replace a center mount brake light bulb. To any of you who have replaced one of these, did you replace the bulb/socket combo, or just the bulb? An online search yielded this: https://www.napaonline.com/en/p/LMAPC175 Thanks, Paul
#2 | ||||
![]() Third brake light lamps may be the oddball ones. I had the same issue with my L300 when trying to replace them Mine are a different number but basically the same type of bulb with plastic bayonet holder. They're one piece units, lamp with bulb holder and replaced as a unit. A quarter turn ccw to remove, quarter turn to lock and connect. When I couldn't find the exact replacements I did the next best repair - buying just the lamps, cutting the leads off the dead bulbs, inserting the new ones in and finagling the wiring to connect the holder to lamp. Testing ensures light operation. A few lamps were replaced over the years. Online exact replacements are just as expensive as the NAPA price per lamp assembly. Lamp packs of two or three are cheaper but you have to setup the lamp wires to connect to the base correctly in order to reuse the bases. Your only option besides this is buying the NAPA bulb as long as the base fits the third brake light sockets.
Other Ion members may have better ideas or links for replacement lights.
#3 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006
2007 ION-2 Quad Coupe
![]() PC175 bulbs are correct, but PC168 bulbs will also work. You have a couple different options.
You can buy six PC175 bulbs from RockAuto for about $12 (including tax, shipping and 5% discount). You can also buy T10 twist lock bases/sockets from eBay or Amazon for about $7. This would allow you to install the cheaper, more common 194/168 bulbs or equivalent LEDs. If you install LEDs, make sure they are red (not white) and make sure they project light out of the sides as well as the top. You may be able to find a set of LEDs that come with the correct T10 bases for less than $10. ... 2007 Ion 2 Quad Coupe 5-speed manual 182K miles 2007 Chevy Equinox LT 194K miles 2018 Chrysler Pacifica Touring L 41K miles
#4 | |||||
2003 ION-3 Sedan
![]() Quote:
Thanks, everyone. I was able to find a 2-pack of the PC168 bulbs for a decent price, so I'll probably give those a shot. Here is the link if anyone else is interested: https://www.topbulb.com/pc168-bulb-2...hilips-pc168b2
#5 | |||||
2003 ION-3 Sedan
![]() Quote:
After more searching I was able to find the PC168 bulb for $1.50 at NAPA though. Thanks again.
#6 | ||||
![]() ![]() ![]() ![]() Join Date: Jun 2013
2008 AURA XE
![]() Oddball place but Home Depot...lol. Free ship to store if not in stock.
https://www.homedepot.com/p/Wagner-L...C175/309151105 ... 2008 Saturn Aura XE 3.5L 4 spd 2000 Saturn SL1 1.9L SOHC (Retired)
#7 | |||||
![]() Quote:
#8 | ||||
2008 AURA XE
![]() I saw that just posted it because Home Depot is local.
LED replacement bulb for 3RD brake light | termite | S-Series General | 2 | 10-03-2017 08:49 PM |
Brake light bulb | cam | Vue General | 1 | 06-17-2014 08:16 PM |
93 SW1 third brake light bulb access | stormtracker | S-Series Tech | 0 | 07-26-2013 05:10 PM |
Right Brake light still out after changing bulb? | astromajor | S-Series Tech | 4 | 03-27-2011 08:25 PM |
EZ Brake Light Bulb Fix | Lee in MD | L-Series Tech | 25 | 09-20-2010 08:21 PM |
