Old 10-28-2019, 10:04 PM   #1
serenitythen
serenitythen has a spectacular aura aboutserenitythen has a spectacular aura aboutserenitythen has a spectacular aura about
Default Slow coolant leak turned major!
I'm writing this from the side of the freeway. I'm letting my 97 Saturn SL2 with 210,000 miles cool down and traffic to lighten up before attempting to add more coolant/water and drive the last 8 miles home.
I've been slowly losing coolant for a few years. It's wet on the engine block near the upper coolant hose, ects, and the transmission underneath. I've added coolant every few months. I figured it's a outer head gasket leak.
The ects is brass and the upper radiator hose is fairly new.
Well tonight the leak got a lot bigger! Now I noticed coolant on the bottom the battery tray too. The bottom side of the upper radiator feels dry so coolant isn't riding down the hose into the battery from that.
Will a leaky head gasket spray or piss some distance??
Any other things to look at? Is there a coolant hose that runs in that area that feeds thru the throttle body?
Now, I can top off the coolant reservoir, drive only 4 miles and the coolant light is already flashing on my dash. That's how fast it's losing coolant. I can't see where it's leaking, pissing, spraying from??
Any tips on what to look for appreciated
Add to serenitythen's Reputation
Rate the quality of this post and help serenitythen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
serenitythen is offline   Reply With Quote
Old 10-28-2019, 10:25 PM   #2
Default Re: Slow coolant leak turned major!
It has been hours now since your post, I hope you are off the road by now.
Yes, fluids under pressure can spray all over, in unpredictable patterns.
Did you loosen/remove the reservoir cap to minimize pressure building in the coolant system?
Add to billr's Reputation
Old 10-28-2019, 10:43 PM   #3
Zeebins
Zeebins's Avatar
Has the radiator ever been replaced?
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 10-29-2019, 01:09 AM   #4
serenitythen
Update:
Got the car home after stopping a total of 6 times for water. Turns out it was a cut in the upper radiator hose that rubbed against the battery tray until a slice opened up. The hose was only a few years old.
I bought a new hose and protected it with armor (I cut a strip from a old rubber car floor mat and wrapped it around vulnerable spots on the new hose and held in place by steel zip ties).
I still may have a occasional outside head gasket leak....or that may been the hose too. But either way, the hose was the reason for today's sudden dumping of coolant.
96 SW1: MAJOR external coolant leak Cyprus S-Series Tech 26 12-27-2010 08:53 PM
Major coolant leak novice S-Series Tech 59 03-04-2010 09:19 PM
Major Coolant leak - 98 SL 1 sickss S-Series Tech 7 12-11-2009 10:27 PM
Slow coolant leak hufhouse S-Series General 1 01-09-2006 10:06 AM
MAJOR coolant leak--water pump? SweetErica S-Series Tech 10 12-27-2004 03:13 AM
