Old 09-02-2019, 12:37 AM   #1
Durvelle27
Durvelle27 is on a distinguished road
Default 05 Vue 2.2L 5 Speed Clutch Goes To Floor
Alright guys Iím having an issue with my 05 Saturn Vue 2.2L 5 Speed. Basically the clutch goes all the way down to the floor with no pressure whatsoever. Iím not sure whatís going on. The car has been driving perfectly fine with no issues at all. I drove it today around town than went to my grandparents house and when I came out to leave car started but clutch went straight to floor so it wouldnít disengage to allow to put in gear. Now with the car shutoff it goes into gear but when started no go. Car has 278,000 miles as I do a lot of out of town driving weekly for work. I checked the reservoir, it was low but not empty. Added fluid but it made no difference.
Add to Durvelle27's Reputation
Rate the quality of this post and help Durvelle27 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Durvelle27 is offline   Reply With Quote
Old 09-02-2019, 06:59 AM   #2
waiter21
2003 VUE 2.2L
Default Re: 05 Vue 2.2L 5 Speed Clutch Goes To Floor
Sounds like either the master cylinder or a slave cylinder.
Is it leaking fluid ??? Look underneath for a puddle of fluid..
Add to waiter21's Reputation
Old 09-02-2019, 08:56 AM   #3
Durvelle27
Thereís no puddle under the car
Old 09-02-2019, 03:09 PM   #4
Durvelle27
Ok it does look like I some some droplets where the engine and the transmission meet
Old 09-02-2019, 04:55 PM   #5
waiter21
2003 VUE 2.2L
278k. I'm impressed. I'd also say your probably near the end..
New clutch and slave is a reasonably easy job to do. If you decide to tackle it, I'd also recommend doing a timing chain.
Old 09-02-2019, 05:11 PM   #6
Durvelle27
Yes mostly highway miles
How easy. Is there a guide floating around. I donít mind doing the work myself
Old 09-02-2019, 05:57 PM   #7
waiter21
2003 VUE 2.2L
Heres a link when I did my clutch:
http://www.saturnfans.com/forums/sho...d.php?t=222576
Heres a link to my timing chain:
http://www.saturnfans.com/forums/sho...d.php?t=218942
2000 SL1 - Soft clutch with no other issues byoc21 S-Series Tech 5 02-01-2014 05:27 PM
Soft Brakes Baron5867 S-Series Tech 59 11-16-2013 11:11 PM
Soft Clutch - Hard shifting Terike Vue Tech 11 07-15-2011 09:44 PM
soft clutch mrbarky S-Series Tech 1 01-24-2008 09:13 PM
trouble shifting, clutch soft jbadler S-Series Tech 6 01-21-2003 10:19 PM
