#1 | ||||
![]() Join Date: Nov 2018
![]() Whats up guys. Hope someone can help me with this. I have a Saturn SL2 2001 with 80k miles on it.
Recently it stopped starting (wont even crank, does nothing) all lights are on, battery is new, everything works. She was running fine and still does when i manage to start it. The way i have gotten it to start is what confuses me the most (doesn't take much to confuse me tbh, as you'll soon see. Im a noob). i was told it might be a starter problem so i googled what the starter was and what it looked like and a lot of people said i could sometimes try to bump the starter while trying to turn it on and it might start. So i hit what looked like the top of the starter and turned the ignition and BAM! she started right away. Turns out though I've been hitting the egr valve and its worked every time till now. I should mention every time i got it to start using the method above it would start no problem 3 or 4 times in a row after drives then i would have to give the egr a good knock to get it to start again. Now she wont start no matter what i try. I've even replaced the egr valve with a new one. let me back up a bit. even when i replaced the old egr valve i would still have to give it a knock to start it. After a day or 2 of starting it like that with new valve NOW she wont start at all. Ive google my ass off about egr systems and their function in a vehicle which is why I'm more confused now than ever as to why a hardish tap on the egr valve would get it to start. Ive cleaned out the pathways, Ive replaced the valve, I checked for codes and the only one that comes up is p0401. BTW I did all of my screw'n around after she stopped starting indefinitely. One more note... I'm pretty low on gas so I'm going to try getting some gas into it when my girl gets back from school and hopefully that's the reason it wont start now. I'll update after i get back. Any help would be awesome. Thanks!
#2 | ||||
![]() Guessing that when you hit the EGR, you basically shook the whole engine including the starter?
$38 for a starter at DB electrical https://www.dbelectrical.com/starter.../sl/1-9-liter/ richpin's starter replacement video https://www.youtube.com/watch?v=YRqE9cqnn7g See attached pics. First is EGR, located at top, driver side of engine. Second is starter, located behind the engine (facing the firewall / rear of car). It is a little bit above the line of the oil pan, but below the air intake manifold. Note that you have to be under the car looking up to see it. Being low on gas will not prevent your car engine from cranking. It would still crank, and start, but maybe sputter and die if it was out of gas. It would crank but only fail to start if you were completely out of gas ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 141k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
#3 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2014
![]() If the car has a good battery that is fully charged, then the starter should turn over the engine to start it. If the car will not even turn over on the starter, you have either a starter problem or a connection to the starter problem.
Starters don't last for ever and when they go they can do so by 'sticking'. That is where the starter solenoid situated usually on top of the motor sticks and doesn't engage with the electric starter motor. A remedy for this is to whack the starter with a hammer to 'shock' the sticking solenoid free. Sometimes it works, sometimes it doesn't. You need to sort out the turning over of the engine first. Once you have fixed that and the starter turns the engine it will fire up and run or it won't. If it doesn't, then you have another issue to deal that is unrelated to the starter.
#4 | ||||
![]() Thanks for the replies.
I also thought that maybe the vibration from hitting the egr was reaching the starter so I tried knocking a sturdy part of the engine to see if it had the same effect but it didn't ( this is when my "trick" was working). Though i can admit that i didn't really try that hard. I'll see what a new starter can do for me. Thanks again.
#5 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
![]() Go with Dbelectrical.com.
Best price, best 2-day delivery and is comparable to any FLAPS product but LOTS cheaper $$$$
#6 | ||||
![]() Yea it really is a heck of a lot cheaper, the one at auto zone was 120ish. Highly appreciate your help and timely responses!!
#7 | ||||
![]() ![]() ![]() Join Date: Jun 2014
1995
![]() if the starter solenoid is not getting voltage to the solenoid it will silent . There are two connections that use 12 volts the solenoid and the starter motor if any circuit not recieving it will not start car .
check ignition fuse in underhood fuse junction box if it blown. Need to see if both solenoid wires on starter are sending 12 volts to it if it is bad solenoid. If no voltage is shown on the solenoid connection .Possible scenario bad ign switch or a bad fuse under the hood junction fuse box.When you turn key does the dash lights come on like brake abs etc . If so test the solenoid with it out of car is another thing u can try. But easier method would be too test voltage at both solenoid and the motor of starter . You will have to test each individually. Take black lead connect to good ground of car and red to top solenoid wires then crank car see if it shows 12 volts. You can check motor before you start solenoid test this will be hot always with 12 volts. You test this by seeing if there is 12 volts to solenoid. The ignition will send 12 volts to the solenoid while you have the key in start cranking postion . The starter motor is the secondary connection that has always a 12 volt hot going to it . If its not hot it possibly a fuse problem if there is 12 there then motor is bad. Last edited by Packard; 11-07-2018 at 08:52 PM..
#8 | ||||
![]() ![]() ![]() Join Date: Oct 2016
![]() Another happy DB Electric customer here. My old one was failing when hot, and I had a 15 year of student driver that I wanted to teach in a manual. My DB Electric starter got a lot of abuse. Starts great.
I have given up troubleshooting when it won't crank. The starters are a weak points in the S Series. I just replace as required and haven't been wrong yet. ... Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018
#9 | ||||
![]() Same issue here. Luckily, Saturnfans had the answer.
Since I post stuff on the "what did you do to your Saturn today" thread for easy reference, I can see I paid $49 for the starter back in April, 2013. So it was fine for 4 years, 50k miles (minimum 2 starts a day, M-F) and still going strong. Looks like I used a bit of duct tape to hold the top bolt in the socket (it kept falling out) until I got it started in the hole. ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 141k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
2005 Saturn Vue turns over, but wont start + IC wont work | BlueVueMN | Vue Tech | 2 | 06-10-2015 05:50 PM |
95 Saturn SW2 wont start | mozzles | S-Series General | 8 | 08-04-2014 09:56 PM |
92 saturn wont start | smokin444 | S-Series General | 2 | 08-25-2011 09:57 PM |
92 Saturn sl2 wont start hot | s brown | S-Series Tech | 6 | 05-12-2010 11:38 AM |
03 saturn vue wont start | chris montague | Vue Tech | 1 | 10-23-2008 10:53 AM |
