Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 06-08-2012, 01:54 PM   #1
rcm
rcm is on a distinguished road
Default serpentine belt
Has anybody found a tool to change out bas belt?
Can you buy just the idler pullies without buying the whole
assembly?
Add to rcm's Reputation
Rate the quality of this post and help rcm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rcm is offline   Reply With Quote
Old 06-09-2012, 02:29 PM   #2
rcm
Default Re: serpentine belt
ok guys after finding the tool for 205.00 i decided to figure out
what to use to compress spring for belt.what work for me was a
6 inch c clamp .I cut grooves in both ends so it wouldnt slip.
It worked great.The idlers are both the same and you can use 6203-2rs
bearings at any auto store for 6.00 instead of 210.00 for the assembly
through gm.Just press or use socket to knock out old bearing and use
socket and vise to press back in unless you have an actual press.
Hopes this helps.I did it all for about 50.00 bucks for bearings and belt.
Serpentine belt NWSaturn247 S-Series General 18 04-01-2012 11:50 PM
Serpentine Belt replacement & Is belt dressing ok? 2002SaturnMan S-Series Tech 3 02-14-2010 01:37 AM
About serpentine belt and belt tensioner xybaby S-Series Tech 5 01-04-2010 12:42 PM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 09:23 AM
Serpentine Belt tmdougherty S-Series Tech 10 09-12-2002 07:10 AM
