Old 06-15-2011, 11:07 PM   #1
HV Fam Wagon
HV Fam Wagon is on a distinguished road
2000 L-Series 3.0L Wagon
2004 L-Series 3.0L Wagon
Default antifreeze leak at sensor
I drive a 2004 LW300 and she has been leaking a little bit of antifreeze. I hosed the bottom side a few days ago and look for any fresh leak this afternoon.
Antifreeze is leaking at a place I don't expect - the crankcase sensor, right underneath the oil filter housing. The sensor does not seem to have any washer or gasket.
The sensor has this marking "Bosch 0261210 183", and "38551". I couldn't find it at SaturnParts.com.
Has this happened to anyone? Is it necessary to change the sensor? Is it necessary to drain the antifreeze from the radiator before fixing the leak?
Add to HV Fam Wagon's Reputation
Rate the quality of this post and help HV Fam Wagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HV Fam Wagon is offline   Reply With Quote
Old 06-16-2011, 04:59 PM   #2
midway
midway is a jewel in the roughmidway is a jewel in the roughmidway is a jewel in the rough
2000 L-Series 3.0L Sedan
Default Re: antifreeze leak at sensor
If it is the sensor below the oil filter housing I think that is the crankshaft position sensor and it should not leak antifreeze. You must have a leak somewhere else and it is getting on that sensor.
Add to midway's Reputation
Rate the quality of this post and help midway reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
midway is offline   Reply With Quote
Old 06-17-2011, 12:02 AM   #3
HV Fam Wagon
Thanks MidWay.
I look all around the crankshaft sensor, but I don't see any signs of coolant above it. All underside of nearby hoses are dry and dusty, but no suspicious antifreeze leak.
Any suggestions, anybody? I hope it's not the head gasket.
Thanks
1998 SW2 antifreeze leak toggenburg S-Series General 9 08-03-2010 06:07 PM
Another antifreeze leak... DeCaff2006 S-Series General 22 06-07-2006 12:18 PM
1995 sl2 - antifreeze leak - where is it? Woogeroo S-Series Tech 22 12-23-2005 07:27 PM
vacuum leak or sensor problem? sps SOHC S-Series Tech 4 12-13-2005 10:51 AM
Small antifreeze Leak SmoothSoundsxtr S-Series Tech 4 10-27-2003 12:47 AM
