Old 05-21-2011, 10:59 PM   #1
xanxost
xanxost is on a distinguished road
2000 L-Series 2.2L Wagon
Default 2000 LW1 remote won't lock or unlock rear doors
On my 2000 LW1, the keyless remote or the unlock button inside the car will not lock or unlock the rear doors or the hatch. The doors will lock and unlock manually. The front doors lock and unlock correctly, even when the car is put in drive (lock) or the key removed from the ignition (unlock), but not the rear doors or hatch. Is there a separate fuse or relay for the back that I'm just not finding? Or is it something else? Anyone have any ideas?
Thanks
Add to xanxost's Reputation
Rate the quality of this post and help xanxost reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xanxost is offline   Reply With Quote
Old 05-22-2011, 03:08 AM   #2
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
Default Re: 2000 LW1 remote won't lock or unlock rear doors
Thanks
maybe a loose ground or some of that wiring thats in the back doors, do the power windows in the back work from the console and the door?
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Anahiem (disneyland): xxx
Tulare: o,(x-atleast 15)
Visalia: x
Add to mattachuz's Reputation
Rate the quality of this post and help mattachuz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattachuz is offline   Reply With Quote
Old 05-22-2011, 08:33 AM   #3
HV Fam Wagon
HV Fam Wagon is on a distinguished road
2000 L-Series 3.0L Wagon
2004 L-Series 3.0L Wagon
I have the same problem on my driver rear door. It's been almost a year now. I would like to fix it too; but I don't know how.
Add to HV Fam Wagon's Reputation
Rate the quality of this post and help HV Fam Wagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HV Fam Wagon is offline   Reply With Quote
Old 05-22-2011, 09:21 AM   #4
xanxost
Power windows are working fine. If it was just one door, I would think maybe a wiring problem in the door or a bad actuator in the door. Three locations makes me think a fuse or relay, or possibly some central wiring that connects those three.
Old 05-22-2011, 11:25 AM   #5
Examine both driver's and passenger side kick panel fuse blocks. Each side has additional relays and fuses, marked on the inside panel.
Old 05-22-2011, 05:55 PM   #6
xanxost
Both fuse boxes have been checked. I saw nothing on the driver side for the door locks. On the passenger side I found 2 fuses (LOCKS, BODY) that are for the door locks, both are good. There are also 3 relays (DRIVER DOOR UNLOCK RELAY, DOOR UNLOCK RELAY, DOOR LOCK RELAY) that also check out as good.
Since the BODY relay is listed for Power Door Locks, Heated Mirror Relay, Liftgate Latch, I'm thinking that there might be some wire in common, possibly coming from the BCM or a problem in the BCM itself. Anyone know if it controls the door locks?
Old 05-22-2011, 06:40 PM   #7
The body control module (BCM) does almost everything the engine computer doesn't. Since its a $400-$1000 replaceable item you'd have to be absolutely sure its not wiring/solenoids/relays related before having GM replace one. The remote transmits to the bcm; synching consists of pressing Lock/Unlock nearby simultaneously until the door locks cycle, about 7 seconds. This confirms xmitter function, bcm receiver circuit and bcm controlling door locks.
The bcm also controls diagnostics through the DLC, Passlock theft deterrent, interior/exterior lighting, drives the instrument panel, etc..
If you can read wiring diagrams I can send pdf's. Pm me an e-mail address that accepts attachments.
Old 05-23-2011, 12:06 AM   #8
mattachuz
mattachuz's Avatar
is it out of the question that the motors in all 3 locations are bad ?did u replace the body relay with a working relay?
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Visalia: x
Old 07-24-2011, 12:34 PM   #9
TommyK
TommyK is on a distinguished road
TommyK's Avatar
2000 SL1
2007 RELAY-3
For the poster who has only one door lock not working, check the contact pins on the forward part of the door and their mating, contact patches on the door jamb. See if there is an obstruction, dirt or corrosion.
I purposely disabled the door lock once on my Relay when a ham fisted co-worker of my wife broke the electric door opener cable by jerking on it too hard. I deduced the door lock pin on that door and placed a bit of tape over the contact patch so the door would remain in the closed/locked position until I could get it fixed. This kept the door from falling off the track, thereby aggravating the damage.
"If you've got time to breathe, you've got time for music." --- Briscoe Darling
A guitars = chick magnet
A Guitar Hero = guy magnet
You do the math.
Add to TommyK's Reputation
Rate the quality of this post and help TommyK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TommyK is offline   Reply With Quote
remote control windows doors lock themselves saas Astra Tech 8 08-03-2010 09:26 PM
Cruise no longer works / Doors do not lock & unlock in park usa4624 Aura General 16 04-24-2009 02:39 PM
remote lock/unlock and starter scalemechanic S-Series General 7 02-06-2009 01:19 PM
Remote Lock/Unlock does not Flash Headlights LTS Vue General 7 05-05-2005 01:06 PM
Aftermarket remote engine starters and remote lock/unlock akide General Saturn Discussion 0 02-28-2003 08:48 PM
