Old 04-05-2011, 10:43 AM   #1
HV Fam Wagon
HV Fam Wagon is on a distinguished road
2000 L-Series 3.0L Wagon
2004 L-Series 3.0L Wagon
Default Any way to clean the air intake?
I have a 2000 LW2.
Last Sunday, I took off the air cleaner box and spray some gumout into the throttle butterfly. A lot of dirt came out. I prop the butterfly open and spray some more into it. It seem there's a whole lot more dirt's still in there. Is there any easy way to clean that area and perhaps also clean the runners a little farther down?
Thanks.
Add to HV Fam Wagon's Reputation
Rate the quality of this post and help HV Fam Wagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HV Fam Wagon is offline   Reply With Quote
Old 04-05-2011, 02:33 PM   #2
BuzzStPoint
BuzzStPoint is on a distinguished road
BuzzStPoint's Avatar
2000 L-Series 3.0L Sedan
Default Re: Any way to clean the air intake?
Are you wanting to clean the air cleaner box and tube?
Assuming your 3.0L?
If so,
Remove all the tubing,
remove the Mass air flow sensor
Clean airbox and tubing with mineral spirits.
Clean Mass air flow sensor with MAF cleaner. (Do no touch the little wires they are brittle).
If you are talking cleaning deeper into the throttle body, buy a gasket from the auto store and remove the throttle body, and give it a good cleaning with some TB cleaner.
Add to BuzzStPoint's Reputation
Rate the quality of this post and help BuzzStPoint reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BuzzStPoint is offline   Reply With Quote
Old 04-06-2011, 12:31 AM   #3
HV Fam Wagon
I want to clean the other side of the butterfly, but I don't want to break anything. The check engine light came on and gave a P1516 code. I cleared it; the wagon seems to run OK.
What gasket do I need? What is TB cleaner?
Old 04-06-2011, 08:05 AM   #4
BuzzStPoint
TB cleaner = Throttle Body cleaner
As for the gasket, should be availible at any auto store, you'll need a throttle body to intake gasket.
Old 04-06-2011, 02:15 PM   #5
HV Fam Wagon
Thanks.
Any pitfalls or anything I need to watch out for?
Old 04-06-2011, 02:53 PM   #6
BuzzStPoint
Only think I can think of is to be careful of the wire clips so you don't break them off. Once you replace the throttle body gasket make sure both surfaces are clean and free of old gasket material.
TB Clean Fox Slaughter S-Series General 0 03-22-2009 03:43 PM
best way to clean intake bubbad4life S-Series Tech 7 05-21-2008 10:09 PM
how to clean intake? help please. sc2dohc94 S-Series Tech 6 03-12-2008 05:34 PM
How do I keep this SL clean !! ttreibel S-Series General 15 06-09-2003 11:21 AM
Easiest way to clean intake manifold? shriek S-Series Tech 7 03-06-2001 10:24 PM
