Old 11-01-2007, 03:58 PM   #1
GmG
GmG is on a distinguished road
GmG's Avatar
1992 SC
Dizzy Help troubleshooting stereo wiring 92 SC & will a 98 stereo work?
The previous owner of my 92 SC really did a job on the stereo wiring, mostly cutting out the stock harness to, I'm guessing, install an aftermarket stereo. I took a stock harness out of another 92 SC to solder in, which I did last weekend. I did my very best to get all the wires in the right places, and there weren't any that I wasn't confident with. The only stereo I had to test my work with was a stock 98 casette stereo. When I plugged it in and turned the key on, the backlight came on, but the clock didn't work. The stereo itself works fine in my 98. I have a digital multimeter to test with, if necessary. Any hints or advise would be greatly appreciated! Thanks in advance!
George
92 SCm 138k
98 SC2m 131k
"You shouldn't leave things in the fridge. That is the lesson."
Add to GmG's Reputation
Rate the quality of this post and help GmG reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GmG is offline   Reply With Quote
Old 11-01-2007, 05:18 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Help troubleshooting stereo wiring 92 SC & will a 98 stereo work?
Check the fuses. Also check to make sure you didnt mix up the yellow speaker wire with the yellow power wire.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 11-01-2007, 05:48 PM   #3
Uzzy
Uzzy has a spectacular aura aboutUzzy has a spectacular aura about
Uzzy's Avatar
2002 SC1
Ya that got me when I had to do the same thing on my '92 when I sold it.
Aut viam inveniam aut faciam
If your ECTS is not brass...your ass is grass.
If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
Add to Uzzy's Reputation
Rate the quality of this post and help Uzzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Uzzy is offline   Reply With Quote
Old 11-01-2007, 05:58 PM   #4
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Happy Re: Help troubleshooting stereo wiring 92 SC & will a 98 stereo work?
Will this help?
Add to SRGW's Reputation
SRGW is online now   Reply With Quote
Old 11-01-2007, 06:01 PM   #5
GmG
GmG's Avatar
1992 SC
Checked the fuse, it was good, also was a 10 amp, so I replaced it with a 5 amp as specified on the cover.
As I recall, enough of the like-colored wires were still in the harness that I'm as sure as I can be that they all went in the right spot in the new harness. Failing that, is there some way I can tell that I got the yellows in the right places?
George
92 SCm 138k
98 SC2m 131k
Old 11-01-2007, 06:05 PM   #6
GmG
GmG's Avatar
1992 SC
Originally Posted by SRGW View Post
Will this help?
Thanks, that does give me the idea that I can test the yellow and orange for voltage in key off/on. Since the display doesn't show a time on it, maybe something is going on there.
I just tried the 98 cassette stereo again, and noticed that it made a split second of static when I turned it on, so I tried a cassette in it, but it will not even accept the cassette.
Only one speaker is installed now, if that makes any difference.
George
92 SCm 138k
98 SC2m 131k
Old 11-01-2007, 06:22 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
Did you check the other fuse? Theres two. 10amp chime fuse and 7.5amp radio fuse.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 11-01-2007, 06:40 PM   #8
Uzzy
Uzzy's Avatar
2002 SC1
There's two browns too. WTF? Would it have killed them to put a damn stripe down a couple of wires? I've never seen a wiring harness withthe exact same colours of wires for two totally different things in a car before!
Sorry, still bitter.
Old 11-01-2007, 06:44 PM   #9
GmG
GmG's Avatar
1992 SC
Yay, the chime fuse was blown! Now, not only does the chime work, but the tape player shows the time, powers up and accepts a cassette.
No audio (I did check my tape and it was playing music in a different player), so I'm going to go to work on speakers. If I don't get any sound by installing one speaker, I'll wait until daylight to fiddle with it more.
Thanks for the help!
George
92 SCm 138k
98 SC2m 131k
Old 11-01-2007, 06:46 PM   #10
GmG
GmG's Avatar
1992 SC
I was thinking the same, while I was thanking my lucky stars the the prior owner had left enough wires uncut for me to (hopefully) deduce the correct position for each wire.
George
92 SCm 138k
98 SC2m 131k
Old 11-01-2007, 07:05 PM   #11
GmG
GmG's Avatar
1992 SC
Sweet, I have one of my speakers in and it works great. Of course, prior owner had cut out the stock speaker connectors so I couldn't use my nice speaker wires from Crutchfield. I just did a basic splice, I'll try to find time to do all four with solder tomorrow, and hopefully it will all work! Thanks again to all!
George
92 SCm 138k
98 SC2m 131k
Old 11-04-2007, 06:35 PM   #12
GmG
GmG's Avatar
1992 SC
Does anyone have a preferred faster for the speakers? Prior owner tossed all the factory fastners and apparently just had the front speakers sitting loose in the doors. The hardware store can't help, all they have are machine screws up to #14, which is a hair too small for the holes, and none of the plastic anchors I tried from them will work, they just spin in the holes, if I can get them in at all. If no one has any suggestions, I'll be off to the dealer Tuesday to get the factory ones.
George
92 SCm 138k
98 SC2m 131k
Need wiring help for '03 L series stereo paxman356 L-Series Tech 0 07-19-2008 04:22 AM
stereo wiring harness 01SC1blue S-Series General 3 11-21-2005 12:24 AM
help please quick wiring stereo defy69 Ion General 6 02-21-2005 12:26 AM
HELP, stereo wiring not working jumpn Vue General 4 11-12-2004 01:42 AM
Stereo wiring TrustyOne Miscellaneous Tech 7 03-30-2003 02:03 AM
