Old 10-12-2019, 01:25 PM   #1
ForceEdge
ForceEdge is on a distinguished road
Default 99 Saturn SL2 engine hesitation, now wonít start
I was driving and the engine started hesitating almost feeing like it was going to stall. So I pulled over and turned the car off. Now it wonít turn back on. Car turns over but never starts.
Any idea what the issue could be?
Having it towed to house now with AAA
Add to ForceEdge's Reputation
Rate the quality of this post and help ForceEdge reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ForceEdge is offline   Reply With Quote
Old 10-12-2019, 02:42 PM   #2
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: 99 Saturn SL2 engine hesitation, now wonít start
Two things to check: 1 Do you hear the fuel pump run for 3 seconds when you turn key on?
Check fuel pump relay for 12 volts. 2 Possible CPS [crank position sensor] bad. Check if plugs are wet with fuel. Check for spark remove 2 plug wires from 1 coil and crank no spark jump CPS is bad.
1995 SL1 236,300 2005>2018
1997 SL1 78,600 2014>????
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-12-2019, 04:12 PM   #3
ForceEdge
Default Re: 99 Saturn SL2 engine hesitation, now wonít start
CHECK YOUR OIL!!
Okay I will check fuel pump thatís an Easy one it sounds like.
If the plugs are wet with fuel that means the CPS is bad?
Also, so I have to remove one spark plug wire from a spark plug and see if thereís a spark when I try to turn the engine on? Maybe Iím not understanding this correctly?
Old 10-12-2019, 08:10 PM   #4
Waiex191
Waiex191's Avatar
With no CPS signal there will be no spark and no fuel, because the ECM can't tell the motor is spinning.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-12-2019, 09:30 PM   #5
The fuel pump will still prime the system for the first 3-5 seconds of KOEO, the PCM just won't fire the injectors. There's a test port in the IPJB to probe with a 12v light which will light up when the fuel pump is commanded on.
Checking for spark usually takes 2 people, one to turn (and hold) the key to 'start' and another one to hold the side of a removed spark plug (plugged back into the plug wire) to an unpainted metal surface on the engine. You could run a 16awg wire with an alligator clip on both ends from the purple wire on the starter to the + on the battery and just leave the key in run if you don't have a second person.
Old 10-13-2019, 09:27 AM   #6
Waiex191
Waiex191's Avatar
You can also use a spare plug, connect the wire, and use a jumper cable to both make ground and hold the plug so you can see it under the hood.
Bryan Cotton
Throttle Hesitation After Cold Start MetalMatty S-Series Tech 9 01-03-2015 11:32 PM
1995 Sl1, hesitation, gas to start, forward gear slam geehawk S-Series Tech 7 08-13-2009 01:05 AM
Warm engine hesitation after start up... groover S-Series Tech 0 07-09-2008 11:16 AM
Engine hesitation from a cold start GojuGuy S-Series Tech 6 05-07-2007 03:48 PM
ECTS, rough start, hesitation probs tzec S-Series General 11 09-19-2005 09:24 PM
