Old 09-29-2020, 08:52 PM   #1
bromli
bromli is on a distinguished road
bromli's Avatar
Question Unmangling speaker wiring on 2000 LS1
I am trying to unmangle the speaker wiring on my 2000 LS1. The previous owner left things in a horrible state. For almost all 4 speakers, the factory wiring is ripped and cut up, and any semblance of factory connectors is replaced by cheapo 14 gauge wiring. I want to fix this and fix this right, so I want to try to find OEM parts if viable.
Are the wires that run from the speaker to the main door wiring harness part of one removable unit? As in, could I swap one from a parts car and bring the wiring system back to stock format? If this option doesn't exist, how could I go about making a long lasting and reliable setup that won't kink or become undone over the lifespan of me opening and closing the door?
bromli is offline   Reply With Quote
Old 09-29-2020, 08:56 PM   #2
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
Default Re: Unmangling speaker wiring on 2000 LS1
Your going to have to get a Haynes or Chilton book for the Saturn model and look at the wiring schematics to find how it is wired. Trying to help this wiring combination rat nest will be a disaster on the forum. Those books will give you the wiring colors and where each goes.
Old 10-01-2020, 02:56 PM   #3
pierrot
pierrot's Avatar
Originally Posted by bromli View Post
...Are the wires that run from the speaker to the main door wiring harness part of one removable unit? As in, could I swap one from a parts car and bring the wiring system back to stock format?
Yes, you can remove the wiring harness from an L-Series door and swap it into another. It's possible, however, that if the harness comes from the front doors of a car that has the advanced sound system that there may be no wires for the tweeter as they're not used in the front doors with that system. The harness also includes the wiring for the door lock, power window, and door light if equipped. (Don't take a harness from an LS or L100 without power windows.)
Even the factory wiring harnesses eventually show wear and tear on their contents between the pillar and the doors especially between the center pillar and the rear doors. The improvement one might make in that space is to splice in a larger gauge wire that could withstand the bending more easily.
339,000 miles - Holy canolli!
Joe Biden for POTUS and Kamala Harris for VEEP. What follows if they get their way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Old 10-01-2020, 04:45 PM   #4
floridasl22002
I would just throw in my 5 cents on this and say that the OEM speakers are built down to a price and as your speakers (if original) are now 20 years old, the paper cones and foam flex rings will have perished by now. I replaced the speakers on my son's 2003 L300 as we could tell his speakers had gone to heaven.
What you will find is that the connectors that Saturn used to connect the wiring to the speakers are specifically for that purpose. The connectors will NOT work on replacement speakers, so you are forced to add new connectors to the speakers as most if not all simply come with male spade connectors. So you are into cutting off the OEM connector and splicing in a new compatible female space connectors whether you like it or not.
Just keep in mind you are driving a 20 year old car that was last produced in 2004 and the Saturn company closed down in 2008. Creativity now comes to the fore in keeping these cars on the road.
Old 10-02-2020, 04:53 PM   #5
Rj 2000 LS2
Rj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the rough
2000 L-Series 3.0L Sedan
My wife turned more then one set of speakers into confetti listening to Levi Parham's song, "wrong way to hold a man" https://www.youtube.com/watch?v=JQf8z_hXKHU Strong bass shredded the stock speakers.
Rj 2000 LS2 is offline   Reply With Quote
Old 10-02-2020, 06:43 PM   #6
SRGW
1997 SL1
Post Re: Unmangling speaker wiring on 2000 LS1
This is the basic system if you need other diagrams let me know.
1995 SL1 236,300 2005>2018
1997 SL1 85,100 2014>????
CHECK YOUR OIL!!
Old 10-02-2020, 07:15 PM   #7
SRGW
1997 SL1
More diagrams.
CHECK YOUR OIL!!
Old 10-03-2020, 09:58 AM   #8
floridasl22002
SRGW.... you have given wiring diagrams for the S sereis. The vehicle and this forum section is the L series. Totally different car.
Old 10-03-2020, 10:46 AM   #9
SRGW
1997 SL1
Sorry first set are for LS1.
CHECK YOUR OIL!!
Old 10-03-2020, 04:44 PM   #10
floridasl22002
CHECK YOUR OIL!!
SRGW,
No need to say sorry. It's me who must apologize to you. I saw your post then immediately saw all the SL1 references below, so it looked like that was the post for S series. Of course, had I opened the diagrtams I would have seen it said LS1. Sorry! Innocent mistake on my part.
Speaker Wiring StrnWolf S-Series Tech 1 01-26-2019 08:09 AM
Speaker wiring???? JerryHughes S-Series General 30 08-21-2017 02:09 AM
Speaker Wiring tmladenka L-Series Tech 2 05-29-2013 04:09 PM
speaker wiring mvsp10@yahoo.co Vue Tech 2 04-05-2010 05:14 PM
Speaker Wiring trans4mer Miscellaneous Tech 4 08-27-2001 11:43 PM
