Old 09-19-2020, 03:24 PM   #1
dummo
dummo's Avatar
1997 SW2
Default The Best Power Steering Fluid
The Best Power Steering Fluid Is...
Should I use my Dex III transmission fluid?
All opinions welcome.
1994 SL1 new traded
1992 SL2 new traded for above
Old 09-19-2020, 04:22 PM   #2
hholbein
1997 SW2
Default Re: The Best Power Steering Fluid
Dex III is the minimum requirement. I run Allison Synthetic ATF Dex III equivalent in my vehicles, and with my Saturn, it really helped with a noisy PS pump with brownish fluid. It's been 15 years since I switched and the synthetic replacement still looks good.
Old 09-20-2020, 10:37 PM   #3
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
I put a Wix 33033 filter in the return line...
https://www.rockauto.com/en/parts/wi...el+filter,6200
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
mattwithcats is online now   Reply With Quote
Old 09-20-2020, 10:50 PM   #4
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
I used SuperTech Dex 3 a few weeks ago and it seems to be happy with it
97 SL2, auto, 120K miles
Old 09-20-2020, 11:47 PM   #5
454cid
PS fluid is something I have not changed on my Saturn. Good to know that people are using ATF, since that's what I'm used to using in my truck even though it's not a GM approved fluid.
Maybe I'll use the ole turkey baster and suck out the fluid from the reservoir..... yes I know that only gets a small amount of it, but I'm not messing with disconnecting hoses on this car when they're all buried.
1999 Chevy K3500
Old 09-21-2020, 02:52 PM   #6
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
^^^ I use a flavor injector I purchased at Dollar Tree. Less mess. I cover the area with ample amounts of paper towels too.
https://www.dollartree.com/cooking-c...jectors/226254
1999 SL2 A4 -91k miles
Currently sipping Valvoline NextGen HM 10w-30
TCW3 dosed fuel
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 09-21-2020, 03:17 PM   #7
454cid
I have a couple of those, but without the extension. I think mine were originally sold for a different purpose. I think I got them out of the trash someplace. They've been rolling around in the bottom of my tool box forever. I finally used one a few weeks ago, but I don't recall exactly what for.
I've got a version that's setup specifically for mixing 2-stroke gas, which is real handy.
1999 Chevy K3500
Old 09-21-2020, 03:29 PM   #8
Zeebins
Zeebins's Avatar
I’d recommend getting a simple siphon pump to get the old power steering fluid out. They are just as cheap as a turkey baster, and they can get into the back part of the reservoir that turkey basters usually can’t reach.
https://www.autozone.com/test-scan-a...B&gclsrc=aw.ds
Old 09-21-2020, 04:32 PM   #9
hholbein
1997 SW2
+1 on something other than the turkey baster. I did 5-6 fluid changes 15 years ago to gradually get rid of 90% of the old ATF in the PS system, and used a turkey baster for the first 3 changes, then it went so much better with a cheap Harbor Freight pump. Less mess and faster.
https://www.harborfreight.com/multi-...ump-63144.html
Old 09-21-2020, 07:18 PM   #10
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
I am a fan of Lucas power steering fluid
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 09-22-2020, 02:39 PM   #11
hholbein
1997 SW2
Also, people have had good luck with Mobil 1/Dex 3 synthetic in old posts.
Old 09-22-2020, 07:02 PM   #12
Pitcher
Pitcher's Avatar
The BEST??
Amsoil ATF. That's all I run, PSF & 5-Speed Tranny.
Owned 4 other S-Series.
Old 09-23-2020, 07:58 AM   #13
Highmile
Highmile's Avatar
If you are going to do a PS flush then do it right. Pull the return line at the rack and turn the steering wheel back and forth until you are not getting much or anything out. Then pour 1/2qt or so in the reservoir and repeat the wheel turning.
then hook up the return line and refill. Turn the wheel back and forth (engine off) until no more air comes out.
Don't be surprised if it's noisy and foams the fluid a bit when you start it.
Highmile
'95 SL1 715k and counting again
Old 10-01-2020, 08:45 AM   #14
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Have used Valvoline PS for years using baster method to clear out old fluid. Try to do this about once a year.
MiSaturn is offline   Reply With Quote
Old 10-01-2020, 11:23 PM   #15
nealt
nealt is on a distinguished road
nealt's Avatar
I am also a big fan of Lucas power steering products.
I topped off and replaced some fluid in my reservoir with Lucas Power Steering Stop Leak. This eliminated my fluid loss and firmed up my steering, making it more responsive. My steering felt like new when I did it.
No question I would use it again.
nealt is offline   Reply With Quote
Old 10-02-2020, 05:44 PM   #16
Macgyver
Mobil 1 ATF is a good balance between the best, availability, and price ($8). AMS Oil is great, but usually has to be ordered.
Brake fluid and power steering fluid leaks sited pierrot L-Series General 40 03-31-2017 12:38 PM
Brake fluid mixed in with power steering fluid! toggenburg S-Series General 6 12-22-2016 01:49 PM
Brake fluid mixed into the power steering fluid sump! toggenburg L-Series General 1 12-21-2016 05:47 PM
Use brake fluid for power steering fluid???? JerryHughes S-Series General 4 02-27-2009 09:14 PM
Power Steering fluid in Brake Fluid southlex Outlook General 4 07-07-2008 03:03 PM
