Old 12-06-2008, 06:49 PM   #1
rmila75
rmila75 is on a distinguished road
Default Damaged front wheel
Today, in barely half an inch of snow, I slid in my 1996 SL1 and went into the curb on my street.
The left front wheel is bent around the rim and looks to be leaning slightly inward. I plan to try to get the emergency spare tire on tomorrow and then drive it to my local mechanic about 2 miles away.
Aside from the obvious need for a new steel wheel, what other issues might I expect to be dealing with here?
rmila75 is offline   Reply With Quote
Old 12-06-2008, 07:18 PM   #2
Default Re: Damaged front wheel
Uhh, you posted in the L-series where there are fewer of us than over in the S-series forums. You can either pm Charlie to move your thread over to the S-series forums or simply re-post again over there.
When you jack up the front end and remove the wheel, you'll get a better look at any other damage behind the wheel - tie-rods, lower control arm, strut, etc.. Turn the steering wheel to see how bad things are or have someone do this while you look for anything else broken.
VCX NANO
Old 12-06-2008, 10:54 PM   #3
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
You may need a wheel alignment even if there is nothing visibly bent. Does the car drive straight - not pulling to one side? Also have a good look where the ball joint connects to the suspension arm.
Old 12-07-2008, 03:01 PM   #4
rmila75
Oops! Sorry, I posted in L series rather than S series.
I got the damaged wheel off and everthing looks OK behind the wheel. I'm sure I'll need an alignment however.
The emergency spare is on and I'll get it to a mechanic tomorrow. Thanks.
Right Front Wheel Wobble alex_0227 S-Series Tech 5 05-30-2009 01:13 AM
Replacing Damaged OEM Wheel LoneHunter S-Series General 10 12-21-2005 03:04 PM
damaged alloy wheel CraigC L-Series General 5 07-28-2005 07:48 PM
The new tyre should be put on front wheel or rear wheel? john_lu General Saturn Discussion 11 05-04-2005 02:47 PM
Damaged front bumper assembly Terry57 S-Series Tech 1 03-11-2005 09:39 PM
