Old 04-14-2008, 11:29 PM   #1
kkspeed
kkspeed is on a distinguished road
Default Upgraded to leather steering wheel; now wheel is off center
Not a major problem, just an observation.
I bought a factory leather steering wheel off a 97 SC2 Coupe from the local Pick-N-Pull for $9.50 to replace the standard wheel on my 95 SL1.
Easy upgrade after renting a puller from Auto Zone.
I noticed after the installation that the steering wheel is slightly off center to the left when driving straight on a level road. Prior to swapping wheels, the original wheel was perfectly centered.
I guess the manufacturing tolerances are not that close on Saturn steering wheels.
Cheap easy upgrade!
kkspeed is offline   Reply With Quote
Old 04-14-2008, 11:33 PM   #2
kkspeed
Default Re: Upgraded to leather steering wheel; now wheel is off center
I forgot to mention that the steering wheel only goes on one way because the steering wheel shaft has square sides.
Old 04-14-2008, 11:39 PM   #3
MichelleG
MichelleG will become famous soon enoughMichelleG will become famous soon enough
Default pop it off
Move it a tooth or 2 to recenter the wheel.....
MichelleG is offline   Reply With Quote
Old 04-14-2008, 11:48 PM   #4
MichelleG
Default sorry
not every having Saturn Sw off...thought it was GM but then again Saturn is a different kind....square you say???? Dang for get my post...
Old 04-15-2008, 06:20 AM   #5
BarnOwl
BarnOwl's Avatar
I have had a steering wheel off on a 2000 and a '97. The shaft wasn't square. I'd like to see a pic of this square shaft. That said, in both cases, the round spline the wheel went on had one tooth that as longer than the others. You can't reorient the wheel there. Get an alignment.
Old 04-15-2008, 07:18 AM   #6
Uzzy
Uzzy's Avatar
2002 SC1
Originally Posted by BarnOwl View Post
Get an alignment.
That's how you fix that.
Aut viam inveniam aut faciam
Old 04-15-2008, 07:20 AM   #7
JerryHughes
JerryHughes's Avatar
1997 SL
If the car is not pulling one way or the other when going down the road and the alignment seems okay, I don't know how but there is supposed to be a simple adjustment you can make to center the steering wheel. Have a look through this thread----------
http://www.saturnfans.com/forums/sho...d.php?t=115738
Jerry
Old 04-16-2008, 06:06 AM   #8
BarnOwl
BarnOwl's Avatar
Jerry
That thread is talking about an alignment adjustment. If you are willing to go and start jacking around with the orientation of your tie rod ends, go ahead but, it's not simple and it's ill advised IMO. It's your tires.
Old 04-16-2008, 07:14 AM   #9
JerryHughes
1997 SL
[QUOTE=BarnOwl;1234689]That thread is talking about an alignment adjustment. If you are willing to go and start jacking around with the orientation of your tie rod ends, go ahead but, it's not simple and it's ill advised IMO. It's your tires.[/QUOTE
Thanks for the info, BarnOwl. Nope, I'm going to leave well enough alone and live with the crooked steering wheel until I need an alignment. The car is driving so nice and straight right now, I'm not going to risk screwing it up. Thanks again,
Jerry
Leather Steering Wheel hufhouse L-Series General 0 12-07-2008 09:09 AM
Steering Wheel Off Center Woody Long S-Series General 21 04-13-2008 09:51 AM
leather steering wheel dtcoastguard Vue General 4 01-14-2005 12:11 AM
Leather steering wheel 95-99 saturn obda Classifieds 1 01-24-2003 04:34 PM
steering wheel of center satfanNJ General Saturn Discussion 3 03-15-2001 02:11 PM
