Old 09-18-2014, 02:42 PM   #1
dougalldc3000
dougalldc3000 is on a distinguished road
Default Strut/Strut Mount Problems
Hey everyone-
I have a 99 SL2 and its wheels keep coming out of alignment. Supposedly, a good year shop told me that the reason it keeps coming out of alignment is because of the strut mounts. I thought that was weird because I just replaced both front struts/mounts/springs a couple years ago and I'm keeping the wheels unaligned for now because I didn't think it would make sense to replace the mounts if I just recently replaced them.
Is there anything I can do to remedy this? Will I have to replace the mounts?
Thanks for your help.
'99 SL2 5-spd DOHC 1.9L 4 cyl w/ lots of mods
'13 Dodge Dart 6-spd 1.4L MultiAir Turbo
#StrictlyAmerican
Add to dougalldc3000's Reputation
Rate the quality of this post and help dougalldc3000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dougalldc3000 is offline   Reply With Quote
Old 09-18-2014, 02:47 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: Strut/Strut Mount Problems
Yeah - that sounds like BS. I think the ball bearings would have to be spilling out of your Mounts for them to be bad enough to mess up your alignment.
Add to Chazberry's Reputation
Old 09-18-2014, 02:51 PM   #3
BV22
2002 SC1
Agree with the above, but to probe further, which aspect(s) of your alignment are changing? Camber changes can occur if the strut to knuckle bolts are not tight enough. Failing ball joints will allow camber to change almost constantly.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 09-21-2014, 02:34 PM   #4
dougalldc3000
I don't know whether it's camber, caster, or toe, all I know is that it's misaligned. I don't think it's loose knuckle nuts but could it possibly be the CV joint? I think my left one needs to be replaced. I sometimes hear a popping noise when turning at a low speed. Thoughts?
#StrictlyAmerican
strut and strut mount advice needed mudawg Vue Tech 20 12-07-2010 10:30 PM
Strut/strut mount/spring removal AJT_Leo S-Series Tech 9 05-24-2010 02:17 PM
Dealer replaced strut, strut mount, and strut bearing tomcatt1 Vue General 17 10-03-2007 04:53 PM
Strut mount problems 00 SW2 opus S-Series Tech 7 06-13-2007 12:21 AM
upper strut mount problems?? satrunracer Miscellaneous Tech 1 07-21-2001 02:59 PM
