Old 11-08-2013, 04:31 PM   #1
02Saturnlady
02Saturnlady will become famous soon enough
2001 SC1
Default Intermittent high idle AFTER Intake manifold gasket replacement
Hello all, fortunately I haven't had cause to be here for awhile. Hope this finds you all well and happy
2001 SC1 SOHC
My problem...I had my intake manifold gasket replaced yesterday by a reputable shop. I didn't drive it much after I picked it up but it drove fine on the way home (approx 3 miles). I've driven approximately 30 miles today and everything was fine for about 20 miles of the trip. Coming through town I hit a stop light and my idle was at 1600 rpm's. It did this with each subsequent stop.
When I arrived home I killed it, let it sit for about 5 seconds and restarted. It then idled fine between 7 & 800 rpms.
I have the brass ECTS. Any ideas? Not sure a broken vaccuum line will cause the intermittent problem. TPS maybe? I don't have the money to start replacing parts willy nilly these days lol.
It's kind of cold out so I haven't started checking vaccuum lines. I did however hit the back of the manifold last night with carb cleaner just to make sure he got a good seal on it and it was fine.
Thanks for any help you can offer.
Add to 02Saturnlady's Reputation
Rate the quality of this post and help 02Saturnlady reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02Saturnlady is offline   Reply With Quote
Old 11-08-2013, 04:51 PM   #2
Default Re: Intermittent high idle AFTER Intake manifold gasket replacement
Disconnect the TPS, spray out the socket and connector and reconnect. Use CRC-QD Electronic Cleaner or equivalent. If you are lucky it is a dirty connection.
Old 02-16-2014, 12:50 PM   #3
02Saturnlady
2001 SC1
Thank you OldNuc for your reply and I apologize for taking 3 months to thank you for it
I pulled the throttle body and cleaned it as well as the TPS to no avail. I replaced the TPS a few days ago with an aftermarket from Autozone. I test drove about 5 miles and everything was fine. The next time I drove it I got a high idle one time and it hasn't happened since so I'm hoping it is now fixed.
My brain no longer functions properly and I can't remember if the computer has to relearn or not (wish my brain was still capable of that lol). I really like my little coupe and it seems to get even better gas mileage than my sl1 or sl2 did.
Thanks again for your help I really appreciate it OldNuc
Old 02-16-2014, 01:52 PM   #4
The problem or issue is that these connectors are rated for a very low number of connect disconnect cycles and then they start having high resistance connections or just no connection and this usually starts showing up as a random event. Over time they just wear out.
SC1 Intake Manifold Gasket Replacement jamesvolson S-Series General 2 02-02-2014 12:39 AM
Changed Intake Manifold Gasket still idling high can_it L-Series Tech 1 12-12-2011 03:45 AM
Intake manifold gasket replacement Yankee1 S-Series Tech 4 01-31-2010 06:25 AM
The Joy of Intake Manifold Gasket Replacement MiSaturn S-Series Tech 0 01-27-2008 11:20 AM
SL1 intake manifold gasket replacement amory S-Series General 30 01-15-2007 04:04 AM
