Old 09-08-2012, 12:21 PM   #1
foreverto
foreverto is on a distinguished road
Default P0010 Error Code - Camshaft Position Sensor
I have a 2009 Saturn VUE XE 2.4L Cylinder DOHC ECOTEC Engine.
The malfunction indicator lamp stays on and displays the error code P0010.
Intake (A) camshaft position actuator circuit/open (Bank 1). The dealer wants ninety dollars to install the sensor. Anyone have any idea exactly where the sensor is located and how to replace it? Do you have to remove any other engine part to get to it? Pictures and diagrams would be appreciated.
Add to foreverto's Reputation
Rate the quality of this post and help foreverto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
foreverto is offline   Reply With Quote
Old 09-08-2012, 12:42 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: P0010 Error Code - Camshaft Position Sensor
I have the extract to replace the actuator - its slightly too large to post. I can email if you send an address by private message (left click on my screen name).
I was able to attach two prerequisite files and description for 2.4 DTC P0010:
http://www.saturnfans.com/forums/sho...d.php?t=184262
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 09-08-2012, 02:36 PM   #3
foreverto
Dizzy Re: P0010 Error Code - Camshaft Position Sensor
The attachment below is what I need help with installing on our 2009 Saturn VUE.
Old 09-08-2012, 02:57 PM   #4
far2grumpy
far2grumpy's Avatar
I never argue with a customer but the CMP shouldn't cause code P0010.
Me thinks you need to replace the intake cam actuator solenoid valve, which would be Item (2) on attached thumbnail:
Old 09-08-2012, 03:15 PM   #5
foreverto
Sad Re: P0010 Error Code - Camshaft Position Sensor
You are probably right. The Advance Auto Tech read the code P0010. I am now confused. If the message reads intake (A) camshaft position actuator circuit/open (Bank 1), I assumed it called for the part camshaft position sensor and not the camshaft position actuator solenoid valve. Looks like I am out of my comfort zone.
Old 09-08-2012, 04:56 PM   #6
far2grumpy
far2grumpy's Avatar
It looks like a simple job to replace either intake of exhaust actuator solenoid.
You'd have to remove air cleaner and engine cover but it looks "like wide open spaces" after that.
See post # 1 of this thread:
http://chevyhhr.net/forums/showthread.php?t=28779
You could also look at this one for updated part numbers:
http://www.saturnfans.com/forums/sho....php?p=1912177
Old 09-10-2012, 08:51 AM   #7
Jalberdi99
Jalberdi99 is on a distinguished road
do you know if that is cover under warranty?
Add to Jalberdi99's Reputation
Rate the quality of this post and help Jalberdi99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jalberdi99 is offline   Reply With Quote
Old 09-10-2012, 09:59 AM   #8
far2grumpy
far2grumpy's Avatar
I don't know ... but I imagine a local GM dealer would know.
I received email from the OP (foreverto) for this thread saying he felt the P0010 repair would be covered under his 5-year / 100,000 warranty.
Old 09-10-2012, 09:07 PM   #9
tiger862
tiger862 will become famous soon enough
2006 VUE 2.2L
Check oil. Make sure you run correct weight and change regular. VVT engines depends on oil pressure to work and if low or needs changing then that would cause these problems. GM went to Dexos oil for this reason.
Add to tiger862's Reputation
Rate the quality of this post and help tiger862 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tiger862 is offline   Reply With Quote
Old 09-10-2012, 10:53 PM   #10
youknowme
youknowme is on a distinguished road
I'd make the dealer fix it. Its a 3 year old car.
Add to youknowme's Reputation
Rate the quality of this post and help youknowme reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youknowme is offline   Reply With Quote
Old 07-05-2017, 08:02 PM   #11
roddant
roddant is on a distinguished road
On my 2008 Saturn Vue, the cam shaft sensor is located on the driver's side on the front of the engine... nothing has to be removed to access it...
Add to roddant's Reputation
Rate the quality of this post and help roddant reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
roddant is offline   Reply With Quote
P0010 Camshaft Position Sensor Eyebolt Aura General 74 10-14-2016 08:17 PM
ODB Code P0341 Camshaft Position Sensor Performance Dave3 S-Series Tech 10 08-16-2012 06:52 AM
Code: P0341 Camshaft Position (CMP) Sensor AtlanticBeach S-Series Tech 36 04-02-2012 08:13 AM
Error code P0341 (camshaft position sensor) huidaman S-Series Tech 11 04-07-2010 04:15 PM
P0341 code Camshaft Position Sensor Isis S-Series Tech 1 04-09-2008 02:55 PM
