Old 07-28-2010, 05:56 PM   #1
cmpcpro
cmpcpro is on a distinguished road
Default Iacv fixed high idle now getting periodic low idle
Hi all once in a while my idle will drop to the point where the car won't idle I'll have to keep my foot on the gas or sometimes I can turn the air on and that will be enough to keep the car running then a few minutes or so the car will return to eight hundred or so. Also my car will ping if I accelerate hard but if I really flog it it will run fine for a little while and you can smell the cat.. I tried cleaning the egr valve but i have to say the little valve looked like it was toast could these all be an egr? Also the other day when I was clearing a high idle code due to iacv I noticed a code that was still in the works for the rear o2... Thanks!
Add to cmpcpro's Reputation
Rate the quality of this post and help cmpcpro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cmpcpro is offline   Reply With Quote
Old 07-28-2010, 10:18 PM   #2
off-track
off-track's Avatar
Default Re: Iacv fixed high idle now getting periodic low idle
Sounds like to me like a new cat may be in your future maybe? (Good luck with that in CA btw!) When it's doing that pull the front O2 sensor and see if it improves.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Fixed my high idle...DOH! Own Stupidity TIMSPEED S-Series Tech 2 02-28-2009 12:00 AM
Intermittant high (2100RPM) idle, Fixed! TvSteve S-Series Tech 0 08-27-2008 02:42 PM
Another High Idle problem IACV? Advice please narov S-Series Tech 9 04-11-2008 04:34 PM
2000 SL1 - Intermittent High Idle – fixed hydromech S-Series Tech 2 05-11-2007 06:06 PM
Occasional High Idle - Fixed (so far) Dubhlachan S-Series Tech 1 03-18-2005 12:14 PM
